Home > Puma (Tdci) > Missing Roll Bars
Page 2 of 3 <123>
jst
ARBs used to be determined by Spec as above. i believe it was 10MY or 11MY that they then all came with them. or were meant too! loads still went out without them. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #406888 12th Mar 2015 1:13pm
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Thanks guys for the info and funny the extreme website has them fitted wrong, someone has indeed offered me a set of bars so I will keep you informed.
I have been driving thinking its fine! amazing what managing ones expectations can do.
I will not be doing extreme off roading so would prefer stable handling especially when braking hard on the motorway, that's an experience!
Post #406995 12th Mar 2015 6:32pm
alby
United Kingdom 2015 Defender 90 Puma 2.2 SW Santorini Black
Weirdly perhaps then Mine doesn't have any ARBs at all. The brackets aren't there either.
It's a 2014MY 64 reg 90sw specced up to almost county spec, it has the standard steel wheels rather than alloys.
Post #407113 13th Mar 2015 1:33am
Looking at at an old MY11 sales brochure County & XS specifcation included:
Boost Alloy Wheel & Continental Conticross Contact AT tyre including locking
wheel nuts (front & rear anti-roll bars are included for 90 Station Wagon only)
and the separate Protection Pack was:
Front mudflaps
Under ride protection bar
Alloy wheels with locking wheel nuts
(not available with 110 3,500kg suspension)
Front and rear anti-roll bars (90 derivatives only)
or Style Pack:
Metallic Paint
Tow Pack (not available with 110 3,500kg suspension)
110 & 130 models all had front & rear anti-roll bars as standard (reading the Load Capabilities page).
The Protection Pack was dropped from the MY12 sales brochure.
For the MY13 & MY14 sales brochures anti roll bars are included if you spec alloy wheels on a 90. 110 & 130 have them as standard.
Post #407181 13th Mar 2015 10:43am
Snowy90
Mine was supposedly a county spec station wagon 90 but was bought new into the RAF I reckon the Mod had a different spec to public ordered cars
Mine have the brackets etc but now bars
Also mine probably didn't have alloy wheels which sounds like it would have mad a difference
So wierd that they were left of many models as the benefits are considerable even at the loss of some axel articulation
Post #407188 13th Mar 2015 11:02am
Cupboard
My poverty spec '11 plate 110 HT has them, and it has very little on it that wasn't standard (apart from a winch).
Post #407248 13th Mar 2015 2:34pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
NickH wrote:
The picture of the rear orange arb shows it fitted wrongly.
The knuckles on the rear axle are the wrong way up, they are hanging below the axle and need rotating......just in case you are intrested......never mind......I will get my coat Embarassed
Are you sure about the orientation? I just fitted a second hand set to my 110 and tried the rear one with the links pointing upwards and it would foul the spring. The front one has the links pointing upwards, as shown in the ever reliable and always accurate Haynes manual Wink
Post #407721 15th Mar 2015 12:28pm
Snowy90
Are there any factory diagrams ie exploded diagrams showing the parts required.
One kind member has offered me a set and it would be good to know what fittings and linkages are needed
Post #407877 15th Mar 2015 9:03pm
Post #407965 16th Mar 2015 10:32am
jonny2tanx
Yep, that shows the front as being above the axle and the rear as dangling below it. The photo of the Extreme arb was a rear one and was shown with the links pointing downwards, or to put it another way, the correct way Razz
Post #408008 16th Mar 2015 12:36pm
Snowy90
Thanks Supacat
Post #408025 16th Mar 2015 2:01pm
munch90
link arms
front point up
rear point down
Post #408027 16th Mar 2015 2:07pm
Snowy90 wrote:
Thanks Supacat
No problem - hope you get all the bits needed.
Post #408050 16th Mar 2015 2:46pm
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
I remember when I ordered my 90 Hard top in March 2011, the dealer advised that if you ordered factory alloys you got arbs, if you went for steel you didn't get any.
I was concerned the brackets wouldn't be there hence ordering with alloys and bars...
However with hindsight, I cant imagine the chassis and axles would be different, so it's probably dead easy to retrofit.
Jonno
Post #408158 16th Mar 2015 6:26pm
Snowy90
I will let you know, a kind member has a set of bars so once I have all the parts I will fit and show some pictures
Excited as I thought it handled ok without so keen to see what difference it makes.
Post #408166 16th Mar 2015 6:30pm
Page 2 of 3 <123>
