Home > Land Rover Customer Relations > Land Rover Recommended Oils We Should Use
Cuthbert
Ryan,
Land Rover recommend Castrol lubricants for the Defender.
If you have access to the technical gurus - Would you provide a definitive answer to the points raised in this thread.
http://www.defender2.net/forum/topic34114.html
Kind Regards
'Bert
Post #388891 15th Jan 2015 10:14pm
Cuthbert
Ryan,
I'm glad I'm not desperate for a response ........... posted on 15th January but would still appreciate a definitive answer.
Post #392813 26th Jan 2015 8:41pm
Cuthbert
Ryan,
Just looked at the calendar and we are now into February and no response. Maybe Ryan has moved on?
Post #395598 3rd Feb 2015 9:52pm
SS90
Still no response.... I could be wrong but I can only presume the question is being avoided as if the points being raised in that thread are true then I can't see Land Rover wanting to admit any liability in their dealers use of the incorrect spec oil. As it could be quite costly mistake for them!
Post #403621 2nd Mar 2015 10:49am
munch90
if you go to Castrol website there is a oil selector put your reg in and it tells you the oil you need
Post #403625 2nd Mar 2015 11:03am
SS90
Not for the 2.2 with DPF they don't, it says refer to dealer...!
Post #403629 2nd Mar 2015 11:18am
CRC@LandRover
Verified Account
Verified Account
Hi All,
Firstly I would like to apologise for the delay on the response. I will be temporarily addressing concerns on this forum and should you require any assistance please do not hesitate to PM me directly.
In answer to the questions raised, for the 2015MY 2.2L Defender we recommend the use of Engine Oil that meets the SAE 5W-30 specification, as has been advised we do recommend the use of Castrol.
While Land Rover do recommend Castrol, there are a number of alternative oils that are suitable, the specification recommended is 5W/30 WSS-M2C934/B and below are a few suggestions.
Shell Helix Diesel Ultra AF-L 5W-30 Fully Synthetic Low SAPS Engine Oil (C1 equivalent)
Mobil Super 3000 Formula C1 5W-30
Castrol EDGE Professional C1 5W-30
Hope this helps,
Many thanks,
Pete
Post #404402 4th Mar 2015 11:19am
Pete
should all main dealers be using an oil to this specification? Is it a recommendation to them from you or an actual requirement?
Post #404410 4th Mar 2015 12:08pm
gilarion
Personally I would never use Castrol no matter what JLR say, I know Castrol claim to be the world’s leading automotive oil producer but I prefer a company that specialises in oil and not the huge petrol chemical industry, that is why I only use Millers fully synthetic. OK it may be more expensive but in this life you get what you pay for. Oil is the life blood of the engine and while I am sure Castrol meets all the specifications it’s just too commercial for me, any oil company and Castrol included that makes supermarket oil or is to be found discounted in supermarkets is not for me.
And if you have an older Defender with a naturally aspirated engine then go for Morris’s Golden Film oil. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #404415 4th Mar 2015 12:42pm
CRC@LandRover
Verified Account
Verified Account
Supacat wrote:
Pete
It is a requirement that Land Rover retailers use the correct specification oil for the specific vehicle.
Many thanks,
Pete
Post #404419 4th Mar 2015 12:47pm
x-isle
If you haven't already seen, there is a sticky in the Puma section which lists a load of WSS-M2C-934-B specification oils available;
http://www.defender2.net/forum/topic34176.html Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #404428 4th Mar 2015 1:09pm
Thanks again Pete Thumbs Up
and x-isle for link. Thumbs Up
I had a minor panic as my invoice for the last servicing itemised Shell Helix Plus 5w/30; but I've just been out to the garage to check the labelling on the 1 litre top up bottle they left in the vehicle and it's actually the Shell Helix Diesel Ultra AF-L 5W-30.
I guess they picked the wrong item on the invoice menu or it's just generic.
Post #404440 4th Mar 2015 1:32pm
that sounds like something I'd pour over my BBQ'd banana Very Happy
Post #404448 4th Mar 2015 2:07pm
Cuthbert
Ryan@LandRover wrote:
Hi All,
Hope this helps,
Many thanks,
Pete
Thanks Ryan/Peter - appreciate you supplying definitive answers and good to hear that you are still around!
Post #404571 4th Mar 2015 9:15pm
