Home > Off Topic > Led lights
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Led lights
Looking to fit led rear lights on the back of my truck are they just a fit and forget or will there be problems with indicators ?
Some company's advertise a little box that you need to fit inline can anyone enlighten me on this
Regards Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #403450 1st Mar 2015 6:33pm
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
If it's led tail/stop lights it's just fit and forget. You only need a ballast resistor or relay for indicators Thumbs Up 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #403453 1st Mar 2015 6:38pm
big steve
Top man it will be a full set with indicators so I will need them cheers mate Thumbs Up 2015 2.2 tdci hardtop xs
Post #403457 1st Mar 2015 6:42pm
Phoenix90
United Kingdom 2007 Defender 110 Puma 2.4 USW Stornoway Grey
Some suppliers will give you a different relay to fit. Then there is no need for the inline resistor.
Post #403458 1st Mar 2015 6:42pm
big steve
But will the different relay affect the front lights that are non led ? 2015 2.2 tdci hardtop xs
Post #403462 1st Mar 2015 6:47pm
Cupboard
I see 3 advantages to LED lights: they come on quicker and sharper (so are less likely to be missed), they don't have bulbs to change, and they use less power.
Fitting a ballast resistor kills the using less power advantage, you're better off fitting an indicator relay that can cope, like the RDX one.
Post #403463 1st Mar 2015 6:56pm
big steve
Hmm 2015 2.2 tdci hardtop xs
Post #403470 1st Mar 2015 7:21pm
grafty99
Most of the led relays available will do incandescent lamps. Why not do the fronts too? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #403501 1st Mar 2015 9:11pm
big steve
Sorry guys the reason I put it in the off topic section is its a Toyota dyna pickup
Post #403502 1st Mar 2015 9:17pm
Cupboard
ah, right. In that case are you thinking of just replacing the incandescent bulbs with LED drop-ins? I don't know whether you'd mind or not but they're technically not legal.
I've no idea how the indicator relay works on them, it might be fine or you might need to change it/put ballasts in. If a bulb goes do they flash more quickly?
Post #403886 2nd Mar 2015 9:32pm
