![]() | Home > Off Topic > Led lights |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 ![]() ![]() ![]() |
If it's led tail/stop lights it's just fit and forget. You only need a ballast resistor or relay for indicators
![]() 2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
Top man it will be a full set with indicators so I will need them cheers mate
![]() 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Some suppliers will give you a different relay to fit. Then there is no need for the inline resistor.
But will the different relay affect the front lights that are non led ? 2015 2.2 tdci hardtop xs
I see 3 advantages to LED lights: they come on quicker and sharper (so are less likely to be missed), they don't have bulbs to change, and they use less power.
Fitting a ballast resistor kills the using less power advantage, you're better off fitting an indicator relay that can cope, like the RDX one. |
Hmm 2015 2.2 tdci hardtop xs
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Most of the led relays available will do incandescent lamps. Why not do the fronts too? 2002 90 Td5 Station Wagon
Sorry guys the reason I put it in the off topic section is its a Toyota dyna pickup
Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
ah, right. In that case are you thinking of just replacing the incandescent bulbs with LED drop-ins? I don't know whether you'd mind or not but they're technically not legal.
I've no idea how the indicator relay works on them, it might be fine or you might need to change it/put ballasts in. If a bulb goes do they flash more quickly? |
