Home > Technical > snorkel |
landy Member Since: 29 Aug 2010 Location: cheshire Posts: 34 |
do i need to fit a snorkel to my td5 before i have a remap?
6th Sep 2010 7:05pm |
Simple answer no! Raised Air Intake or Snorkel may aid/increase airflow under certain conditions but will not 'be taken into account' by usual mapping, so it makes little or no difference to the end result! If you go through life with your head in the sand....all people will see is an ar5e!!
6th Sep 2010 7:10pm |
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 |
a friend of me had lose hp with snorkel.
i have heard that td5 and snorkel don't love each other www.newfoundland.gr |
6th Sep 2010 8:19pm |
cheers guys just one more thing which snorkel will fit without having to move my aerial
6th Sep 2010 8:37pm |
Landy,
With the Safari Snorkel you do not need to move the aerial aparently! See here: http://www.landyzone.co.uk/lz/f7/snorkel-f...49071.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
6th Sep 2010 9:13pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
no aerial issues with the safari
Apparently Safari are the only manufacturer that monitor airflow as part of their snorkel design Mike |
6th Sep 2010 9:51pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5682 |
Mantec snork does not need ariel to be moved and was designed with Land Rover to be fitted to the Td5.
Andy |
7th Sep 2010 6:59am |
thank everyone going to buy a safari i think
7th Sep 2010 6:23pm |
I bought a Safari - no regrets! If you're unsure here may be a good start to have a look for comparisons.... http://www.defender2.net/forum/topic2105.html At the risk of antagonising Discocuzzy I'm going to post a picture....No wheel/tyre combo so I should be ok... Does give a good comparison view I think... Click image to enlarge The elephant trunk is mine and the trilby hat Fekete's. Hope this helps. If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Sep 2010 6:36pm |
cheers for the pic i like both of them i even like the oem land rover one which i can get for £90 now i am confused
8th Sep 2010 7:08am |
