![]() | Home > Technical > snorkel |
landy Member Since: 29 Aug 2010 Location: cheshire Posts: 34 ![]() ![]() |
do i need to fit a snorkel to my td5 before i have a remap?
Simple answer no! Raised Air Intake or Snorkel may aid/increase airflow under certain conditions but will not 'be taken into account' by usual mapping, so it makes little or no difference to the end result! If you go through life with your head in the sand....all people will see is an ar5e!!
pouf Member Since: 05 Aug 2010 Location: Athens Posts: 456 ![]() ![]() ![]() |
a friend of me had lose hp with snorkel.
i have heard that td5 and snorkel don't love each other www.newfoundland.gr |
cheers guys just one more thing
Landy,
With the Safari Snorkel you do not need to move the aerial aparently! See here: http://www.landyzone.co.uk/lz/f7/snorkel-f...49071.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5068 ![]() ![]() ![]() |
no aerial issues with the safari
Apparently Safari are the only manufacturer that monitor airflow as part of their snorkel design Mike |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5804 ![]() ![]() |
Mantec snork does not need ariel to be moved and was designed with Land Rover to be fitted to the Td5.
Andy |
thank everyone going to buy a safari i think
I bought a Safari - no regrets! ![]() http://www.defender2.net/forum/topic2105.html At the risk of antagonising Discocuzzy I'm going to post a picture....No wheel/tyre combo so I should be ok... ![]() Does give a good comparison view I think... ![]() Click image to enlarge The elephant trunk is mine and the trilby hat Fekete's. Hope this helps. ![]() Treat every day as if it is your last....one day you will be right!! |
cheers for the pic
