Home > Maintenance & Modifications > Pink connector block behind passenger headlight?
Page 1 of 3 123>
Jim_Bean
Guys,
What is this connector block for, the one with the pink block? I have a MY13 2.2 Puma.
I noticed a knocking noise and found this unconnected lead swinging freely around behind the headlamp on the passenger side.
I have a nasty feeling its to do with the alarm and immobiliser. What should it be connected to? I can see anything obvious behind the headlamp.
I will be parking the wife's car in front of it tonight until I can confirm what the function of it is.
Post #398744 14th Feb 2015 2:36pm
ibexman
Headlight levelling motor?
Post #398746 14th Feb 2015 2:47pm
mk1collector
The small block is for the headlight levelling motor but the bigger brown and pink one is for a battery back up sounder
Ray
Post #398747 14th Feb 2015 2:54pm
Jim_Bean
No that is the other small rubber boot, next to the 3 way block for the headlamp connection.
The rubber boot is on both sides and connects to the levelling motor.
The pink block is only on the passenger side and connects to nothing at the moment!
Post #398748 14th Feb 2015 2:54pm
K9F
Could be as stated above. If you can determine how many cables go to it and their colours if it is the levelling motor there will be three cables to pins 1,2 and 3 (4 unused). Pins 2 & 3 will be coloured the same on both, black and orange respectively. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #398749 14th Feb 2015 2:55pm
Jim_Bean
Thanks Ray.
I thought so! SO i guess someone has had a go at disabling the alarm.
Whereabouts to I plug the lead back in?
Post #398750 14th Feb 2015 2:56pm
mk1collector
They don't all come with a bbus from factory so it may not have one. If it does you should be able to see the large black squarish horn either from under the bonnet or through the headlight hole in that corner with a corresponding connector on the back.
Ray
Post #398751 14th Feb 2015 2:59pm
K9F
If it is indeed the BBUS all four pins are used and all the cables are black in colour going to the connector. Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #398752 14th Feb 2015 3:00pm
Jim_Bean
Thanks guys.
I'll go see if i can plug it back in!
Post #398754 14th Feb 2015 3:04pm
mk1collector
Did you find it?
Post #398900 14th Feb 2015 11:06pm
Jim_Bean
No - no joy from the bonnet or wheel arch and my hands are too big to reach anything in the headlight aperture!
I guess the connection must be behind the snail horn somewhere.
Post #399054 15th Feb 2015 5:43pm
munch90
you may find you don't have the bbus fitted anyway , as far as I know they don't unless you pay for the alarm upgrade when new
Post #399062 15th Feb 2015 6:06pm
Jim_Bean
You would have hoped that Land Rover would have at least covered the terminals with a blanking plate if you didn't have the BBUS fitted!
Surely water/crap etc will just fill up in there. I've taped it up for now and will give the stealer a call tomorrow.
Post #399091 15th Feb 2015 7:09pm
mk1collector
Not usually covered unfortunately.
Post #399094 15th Feb 2015 7:17pm
Jim_Bean
So do you have the same block just left uncovered from the factory? Mine is now mummified in tape Very Happy
Post #399096 15th Feb 2015 7:19pm
Page 1 of 3 123>
