Home > Maintenance & Modifications > Pink connector block behind passenger headlight? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Headlight levelling motor?
14th Feb 2015 2:47pm |
The small block is for the headlight levelling motor but the bigger brown and pink one is for a battery back up sounder
Ray |
14th Feb 2015 2:54pm |
Jim_Bean Member Since: 10 May 2011 Location: Staffordshire / Shropshire border Posts: 613 |
No that is the other small rubber boot, next to the 3 way block for the headlamp connection.
The rubber boot is on both sides and connects to the levelling motor. The pink block is only on the passenger side and connects to nothing at the moment! |
Could be as stated above. If you can determine how many cables go to it and their colours if it is the levelling motor there will be three cables to pins 1,2 and 3 (4 unused). Pins 2 & 3 will be coloured the same on both, black and orange respectively. If you go through life with your head in the sand....all people will see is an ar5e!!
Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 14th Feb 2015 3:00pm. Edited 2 times in total |
14th Feb 2015 2:55pm |
Thanks Ray.
I thought so! SO i guess someone has had a go at disabling the alarm. Whereabouts to I plug the lead back in? |
14th Feb 2015 2:56pm |
They don't all come with a bbus from factory so it may not have one. If it does you should be able to see the large black squarish horn either from under the bonnet or through the headlight hole in that corner with a corresponding connector on the back.
Ray |
14th Feb 2015 2:59pm |
If it is indeed the BBUS all four pins are used and all the cables are black in colour going to the connector. If you go through life with your head in the sand....all people will see is an ar5e!!
14th Feb 2015 3:00pm |
Thanks guys.
I'll go see if i can plug it back in! |
14th Feb 2015 3:04pm |
Did you find it?
14th Feb 2015 11:06pm |
No - no joy from the bonnet or wheel arch and my hands are too big to reach anything in the headlight aperture!
I guess the connection must be behind the snail horn somewhere. |
15th Feb 2015 5:43pm |
you may find you don't have the bbus fitted anyway , as far as I know they don't unless you pay for the alarm upgrade when new
15th Feb 2015 6:06pm |
You would have hoped that Land Rover would have at least covered the terminals with a blanking plate if you didn't have the BBUS fitted!
Surely water/crap etc will just fill up in there. I've taped it up for now and will give the stealer a call tomorrow. |
15th Feb 2015 7:09pm |
Not usually covered unfortunately.
15th Feb 2015 7:17pm |
So do you have the same block just left uncovered from the factory? Mine is now mummified in tape
15th Feb 2015 7:19pm |
