Home > Puma (Tdci) > Foglight switch for rear wok light |
michaelwl Member Since: 19 Nov 2014 Location: Durban Posts: 65 |
Marius,
Try here you might find one: https://onedrive.live.com/?cid=4BC2D89C85C...C171%21551 2002 110 TD5 White 1981 S3 R6 Matt Green - Now used as game viewer 2013 Discovery 4 XS |
11th Feb 2015 8:03am |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
...the sort of thing you had in mind...
Sorry, just couldn't resist... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
11th Feb 2015 9:00am |
x-isle Member Since: 26 May 2011 Location: Midlands Posts: 1327 |
I didn't use a fog light switch, but here is a 2 way diagram that did when I put mine in. Rocker switch on dash and rocker switch inside rear door. If you are just using one switch, you can just imagine the diagram without the 2nd switch and all is the same. I mounted the relay behind the rear right speaker panel where the "Purple" and "Black" wires can be found providing permanent live.
Click image to enlarge However, if you are using a standard Fog Light switch, I believe these are the pin-outs for the switch; (The switch connects the earth feed, hence 2 Earth connections) Pin 1: Earth (incoming) from relay (Pin 85 on the above diagram) Pin 2: Bulb (Dash lights) - connect into feed of dash lights from the other switches. Pin 3: Earth (outgoing) connect to a ground point Pin 4: Not used. Pin 5: "On" light - This is the same as the Dash Warning light shown on the diagram. For more photos, take a look at the last but one post in this topic - http://www.defender2.net/forum/topic7022-15.html Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
11th Feb 2015 11:04am |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
Ok, so if I understand correctly it would be something like this:
Click image to enlarge |
13th Feb 2015 11:38am |
As far as I'm aware, that's spot on!
If I've got the pin outs on the switch wrong, it won't damage anything, but might be a case of trial and error. However, I'm 95% certain I've got it right EDIT: I can't remember if the standard Rear Fog Light switch is a clicky one or momentary switch? If it isn't a clicky one, then you can't use it for the rear light.......... Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
13th Feb 2015 11:41am |
CAN'T BE DONE!!!!!!
I just went and checked (you can tell how often I used my rear fog light). The switch is indeed a momentary switch which means it doesn't control the fog light, it will be controlled elsewhere, probably by the ECU depending on headlight conditions. What this means is if you use it to control your work light it will only work if you held down the button, when you release the button the light will go back out as it doesn't click into place. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
13th Feb 2015 11:53am |
Yes it's not a click switch..... damm
13th Feb 2015 12:53pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6611 |
Buy a cheap latching switch [ heated seat ~£8 ] and swap the button over? 1988 90 Td5 NAS soft top
2015 D90 XS SW |
13th Feb 2015 1:05pm |
^^ Good idea!
Suspect the pin outs will probably be similar too. Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
13th Feb 2015 1:12pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5729 |
Yep that's what I did. I used a heated rear window switch, and swapped front.
Andy |
13th Feb 2015 1:14pm |
Heated seat switch is:
1 +ve IN 2 Illumination 3 not connected 4 +ve OUT 5 Earth The LED is connected internally across +ve out and earth so it illuminates itself 1988 90 Td5 NAS soft top 2015 D90 XS SW |
13th Feb 2015 1:15pm |
It seems like it's the same then as the switch will probably work as an earth switch too.
Pins 3 & 4 probably do the same, I know on the fog light switch that Pin 4 works the same as Pin 3 even though it's not used. The only thing is, will the LED still light? Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography Last edited by x-isle on 13th Feb 2015 1:21pm. Edited 1 time in total |
13th Feb 2015 1:20pm |
Note that the heated seat and rear heated screen switches are positive side switching, to illuminate their own internal status LED.
This would require a change to the wiring diagrams. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
aha, and there you go.
Just need to move the switch to the other side of the relay, feeding 86 Craig Rogers 2007 Puma 110 XS 2011 Evoque Coupe Dynamic Lux www.craigrogers.photography |
13th Feb 2015 1:23pm |
