Home > Maintenance & Modifications > Engine oil / viscosity question... |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Given the alleged delicate nature of mitsubishi engines I would be wanting the oil to be as specified in the manual. Rhubarb and custard let fly with their secret weapon.
5th Feb 2015 5:17am |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
You wont get such good cold oil/engine protection with 15W/40 as you would 5W/30, but warm conditions the 15W/40 will be better.
The first number is cold rating. so the lower the better, second is the hot rating, so higher the better 0W/40 would be the ideal oil but it costs an absolute fortune! also check the ACEA rating make sure it's compatable with Mitsibishi's spec. Simply B1 or C3 etc is good enough, no need to review entire spec Anyway, as said, I wouldn't be happy with a 15W if Mitsibishi clarify 5W .. take it back Guns and Landrovers .... anything else is irrelevant. |
5th Feb 2015 9:20am |
manufacturer might list one oil , but autodata ( which most garages use ) , may list 5 different oils depending on temp/use etc
put exact model , year , engine etc and I will have a look or reg by message |
5th Feb 2015 11:40am |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Great, it's a 2007, the newer model, 118kw (160bhp) 3.2 with a DPF. It's the current shape, they changed it in 2007.
Cheers |
5th Feb 2015 11:44am |
reg wont go in , so done manually, 06 on , 3.2 with dpf
there is a 15/40 listed for -15 degrees up as long as its c1,2 or 3 and low ash there are 8 different oils listed |
5th Feb 2015 12:07pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
I bet they have used a semi synthetic 15/40 as its cheap as chips!!
When I purchased my wifes Audi the garage serviced the vehicle and put in 15/40 semi, I let it go for a couple of thousand miles then put in the correct oil fully syn 5/30 A3/B3. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
5th Feb 2015 12:17pm |
Thanks for the replies folks.
Just got back from the garage as my 90 needed an MOT. They have made some enquiries to the motor factors and oil manufacturer, they are going to drop the oil, do an engine flush and fill with 5w30. FOC of course. They said sorry and that the motor factors had agreed the oil was the wrong type and that they are supplying new oil, flush etc for the garage. At least no harms been done in the last couple of days. Cheers again Paul |
5th Feb 2015 1:05pm |
