Home > Puma (Tdci) > LED interior lights continually glow - why ?? |
MarkM61 Member Since: 11 Dec 2014 Location: Brisbane Posts: 11 |
http://sdrv.ms/199QUa1
Black wolf, I just looked a the the puma 2.2 wiring diagrams in the link above, posted in another thread by Daniel. It shows the door switches switching the alarm unit, which switches the interior lights, so you are 100% correct, it is the off state leakage current of alarm unit output. Anyway, LEDs will not flatten the battery more than incandescent lights, as leakage is always there regardless of bulb type |
1st Feb 2015 3:25pm |
The fact that this happens tells you it's the 10AS:
Any sort of solid state switching will cause this, it's called leakage current or quiescent current, that is current in the off/inactive state. It really is nothing to worry about in this case. If you're trying to design something with a really low power consumption then it might be, for instance most voltage regulators will merrily munch a few mA all the time (see the Blue Sea USB sockets for instance) and if your total power budget is only a few mA continuous then you have to be aware of it. When I next have my interior light apart I'll measure it, but I would guess that the drain will be <1mA. |
1st Feb 2015 7:29pm |
I installed this, three years ago, on the back (in the front I have the roof console also with led) and is still working ...
http://www.ebay.co.uk/itm/LED-PANELS-PIAST...566ae9b109 Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
29th Mar 2015 10:44pm |
MrConfidence Member Since: 11 Feb 2012 Location: Munich Posts: 5 |
Had the same problem... go buy some dimmable LED bulbs with built-in capacitor.
Works well since then. |
16th Apr 2015 3:24pm |
Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630 |
Have you got a link to a supplier?
Thanks Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
20th Oct 2015 9:48pm |
http://www.conrad.de/ce/de/product/704320/...nhalt-1-St
They will also post to UK... |
21st Oct 2015 7:12am |
Thanks... I have friends in Germany... So I'll get them to sort some for me..
Regards Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
21st Oct 2015 1:28pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Here are a few pix of what's happening, taken in my truck when I fitted LED interior slabs.....
Pic 1. 12v, interior light fully on Pic 2. 5v at the time I took the pic, interior light fading down using PWM... Pic 3. Interior light off, but with about 1.7v flowing.. This is for the alarm to know if the bulb is shagged, and forms part of the alarm trigger circuit.. Click image to enlarge Click image to enlarge Click image to enlarge ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
21st Oct 2015 6:50pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Has anyone found LED bulbs that don't cause a glow and still save on the draw of the existing bulb?
25th Feb 2016 1:27pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
Yes, have a read of this http://www.defender2.net/forum/topic42345.html 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
25th Feb 2016 1:33pm |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
Conrad UK supply - http://www.conrad-electronic.co.uk/ce/en/p...tent-1-pcs NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
25th Feb 2016 3:55pm |
Gonarezhou Member Since: 08 Mar 2015 Location: White River Posts: 178 |
Happens with mine. Even with LEDs fitted by the dealership. Did not at first but do now. Actually quite like it ... a bit like an airliner with the lights dimmed.
25th Feb 2016 8:15pm |
