![]() | Home > Puma (Tdci) > Digital Tachograph Buying & Fitting recommendations |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 ![]() ![]() ![]() |
There is a place in Bristol think they do all the utility ones by the sound of things. Just not a cheap excersise. Will have to look myself soon so be interested in any suggestions
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2673 ![]() ![]() |
If buying for a Defender, Does it really need one? I thought the Defender came under the duel purpose vehicle regs and was therefore exempt 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
Regret so,, For what Leon what to do,, no option
![]() Main Brian James Trailer Dealer for South West UK |
martinfiattech Member Since: 13 Nov 2013 Location: leicester Posts: 422 ![]() ![]() |
Don`t buy a ACTICA one we`ve had issues with finding back up from them, when they go wrong.
Look into a siemens vdo make usually pretty good, and there are more dealers with the kit to set them up and repair them. Welcome to the world of drivers hours and strange symbols ![]() |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 560 ![]() ![]() ![]() |
Give Sherwood truck and van a ring at Sheffield, Malc does a lot of retrofits to various vehicles, the best make in my opinion is the continental 1381 tachograph quite a reliable unit, I fit tacho's myself and they are a better unit
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Ahh the actia digital tachograph! What a pain in the a**e to use and calibrate thankfully I don't think there available now! Siemens VDO is the the Previous name for Continental. Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Anyone have a idea of cost to a 2.2?
if you tow for benefit and profit and MGW is higher 3500 KG for 90 tachograph must be fitted and work the only exempt are WPD,SSE, power and utility MOD fire, police, also you must have driver qualification Card 35 HR in class room ![]() Last edited by dorsetsmith on 18th Jun 2016 5:23pm. Edited 1 time in total |
Xelr8 Member Since: 26 Aug 2014 Location: Sheffield Posts: 165 ![]() ![]() ![]() |
Thanks for the suggestions so far.
I have been quoted 1550 fitted so far but I was hoping to get it a bit cheaper ![]() |
redhandluke Member Since: 02 Jun 2013 Location: Northern Ireland Posts: 243 ![]() ![]() ![]() |
I use Siemens Vdo in my sweepers, annual service and no probs.
Steve |
If you're referring to Driver CPC then it's not required as this is based on the Class of Vehicle & a Defender is Class N1 |
It's expensive as it is a new install the pulse adaptor is dear aswell as the secondary speed signal device which is now require on all new vehicles / installs
There's nothing stopping you fitting it yourself and just taking it to be calibrated, there not that difficult to do. Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
I think you mean 3500kg not 2500kg.
I`ve fitted a few my self, basic common sense and mechanical / electrical knowledge. Is all that`s needed.
The biggest issue I`ve had is where to mount the tacho unit it`s self, especially in a defender as there is`ent much room. It`s the same size as a single din car radio. Also check on the parasitic drain of the unit while the vehicle is idle. I`ve had a few school mini buses, which stand around all week with the tacho slowly draining the battery. Excuse the spelling I`am better with spanners and wires. |
