Home > Puma (Tdci) > Digital Tachograph Buying & Fitting recommendations |
YES |
31st Jan 2015 3:03pm |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3149 |
When I had mine fitted it was about 1500ish all-in.
Mine was mounted on the side of the cubby box, but a better idea would have been to move the lid back and mount the tacho inside the cubby. The lid being moved back leaves a gap so you can see the unit, you MUST be able to see the unit when driving. Ref exemptions for public utilities, this is not actually correct, the exemption is dependant on the work they are doing, emergency repairs is exempt, new works for profit is not. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
1st Feb 2015 9:35am |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
We sell a lot of this cubby to users installing Tachos
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
1st Feb 2015 10:07am |
Sphere Member Since: 26 Apr 2013 Location: Midlands Posts: 725 |
My pereferd location. But ordered mine with the sub on the cubby, guessing shouldn't be to difficult to swap
1st Feb 2015 7:58pm |
Very easy, four small bolts through the rear
1st Feb 2015 8:00pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 556 |
You will need to add a tachograph warning light with the drivers field of vision if mounting the tacho in the cubby box area
Regards Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
1st Feb 2015 10:45pm |
