Home > My Defender > Defender 110 XS No5 2015MY
Page 8 of 11 <123 ... 78 91011>
TJ101
They say they have replicated the error, and it momentarily cut power to the engine, possible on gear changes, and is the extra instrument (Scangauge to you and me) that is plugged into the OBD socket !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391643 22nd Jan 2015 11:06pm
bell-auto-services
I find it hard to beleive that having it attached it can cause a O2 fault as im sure you do. I think its more of a coinsidance that the fault came back as the pulgged the tool in may be or its just not repeated its self yet without it plugged in ?
It can for sure be very hard and a pain in the rear to find the real and in some cases multiple source some times as can any electrical fault and one min its fine and the next its not, thats the problem with finding intermitant faults I suppose, but its easer to say we have not yet found the fault V its the scanguage I feel.
That said im sure they are doing their best to help so all is said without trying to offend them.
Post #391726 23rd Jan 2015 10:06am
TJ101
Thanks Pete, your input is of great value as normal Bow down
Well they say they have unpluged the scangauge and the cruise control throttle interface, and the fault has not reappeared in 80 miles of road test !!!
We will see Rolling Eyes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391756 23rd Jan 2015 11:43am
walfy
So who pays for the fuel for that extended test drive?? 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #391864 23rd Jan 2015 5:48pm
TJ101
Just worked it out,, done 152 miles from dropping off, to collection this afternoon !!! Confused California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391867 23rd Jan 2015 5:57pm
walfy
Thats a cheeky test drive then. They only drove a couple of miles in mine this week to diagnose the fault. 3 rd time its been in for it though Sad 110 D250 SE HT
110 USW SOLD
Post #391871 23rd Jan 2015 6:18pm
bell-auto-services
It is a tough problem with electrical faults especially that are intermittant, sometimes the car does need longer test drives but it then comes to a point where the workshop has to say its not come back on in X miles return the car to the customer.
The tough world of intermitant fault repairs Sad
Post #392054 24th Jan 2015 9:24am
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
Would you have a bill-of-materials that you used for the twin battery install. I have the Bluesea relay and fuse box and I'm trying to make sure I order all the rest of the bits in one go. What size cable did you use..?
Simon
TJ101 wrote:
First few "adjustment" done
Twin Odyssey PC1500, via a Blue Sea 7622 ACR
With aux battery feed to the aux fusebox, via a master cut off switch to under the drivers seat, with all the other fuses
Post #392058 24th Jan 2015 9:51am
TJ101
Evening Simon
No bill as such,, most i had in "stock" anyway
To save any hassle, i did order the full kit from Tim at MCL http://www.mobilecentre.co.uk/index.php?ma...cts_id=726
Cable was 50mm for the winch and front Anderson connector Rest is 16 and 35mm
all auxiliaries via a 250 amp Durite HD master switch. California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #392190 24th Jan 2015 7:39pm
couplands
No worries, I've looked at Tim's kits so may go that way.
Did you put an isolator in the winch lines..? I have an Albright relay to isolate mine, but wondered if a mechanical isolator was a good idea too.
Simon
Post #392195 24th Jan 2015 7:48pm
TJ101
Top (first) picture, Top left, you can see the HD Isolator
Aux battery feed via isolator to busbar for Winch, Anderson and aux fuse box etc California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #392209 24th Jan 2015 8:08pm
TJ101
After being through a few owners, and never fitted, found some time this evening to fit these
Entreq rear Splash Guards
Post #392834 26th Jan 2015 9:18pm
TJ101
TJ101 wrote:
Well they say they have unpluged the scangauge and the cruise control throttle interface, and the fault has not reappeared in 80 miles of road test !!! We will see Rolling Eyes
Well in total, they did over 150 miles road test. during which they fitted a new 02 sensor, and disconnected the cruise and scangauge ??
Since done 60 odd miles without both, all good,, refitted the scanguage, and another 50/60 and still all good,, then refitted the cruise control, another 80/100 miles, with numerous stop/starts to cycle the system,, and still no light Exclamation so maybe the 02 sensor that it when in for as being the problem, has cured it ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #395390 3rd Feb 2015 9:12am
TJ101
A downside to the 18" Bowler Alloys,, (or any other with more outset )
Started off clean,, but 10 miles cross county later !!
Needs a mud/splash guard of sorts made between the bottom of the wheel brows and mudflaps, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #397683 10th Feb 2015 6:17pm
TJ101
So Plan A
After being pointed to Kevin's Mudstuff site and his DIRT D-FENDER http://www.mudstuff.co.uk/110-dirt-d-fende...nsion.html
Ordered Sunday, Arrived today and fitted,,
Stainless pan machine screw's rather than the supplied pop rivets
That should save the paintwork !! see how long they last ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #397684 10th Feb 2015 6:20pm
