Home > My Defender > Defender 110 XS No5 2015MY |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2232 |
I find it hard to beleive that having it attached it can cause a O2 fault as im sure you do. I think its more of a coinsidance that the fault came back as the pulgged the tool in may be or its just not repeated its self yet without it plugged in ?
It can for sure be very hard and a pain in the rear to find the real and in some cases multiple source some times as can any electrical fault and one min its fine and the next its not, thats the problem with finding intermitant faults I suppose, but its easer to say we have not yet found the fault V its the scanguage I feel. That said im sure they are doing their best to help so all is said without trying to offend them. |
23rd Jan 2015 10:06am |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Thanks Pete, your input is of great value as normal
Well they say they have unpluged the scangauge and the cruise control throttle interface, and the fault has not reappeared in 80 miles of road test !!! We will see California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
23rd Jan 2015 11:43am |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2658 |
So who pays for the fuel for that extended test drive?? 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
23rd Jan 2015 5:48pm |
Just worked it out,, done 152 miles from dropping off, to collection this afternoon !!! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
23rd Jan 2015 5:57pm |
Thats a cheeky test drive then. They only drove a couple of miles in mine this week to diagnose the fault. 3 rd time its been in for it though 110 D250 SE HT
23rd Jan 2015 6:18pm |
It is a tough problem with electrical faults especially that are intermittant, sometimes the car does need longer test drives but it then comes to a point where the workshop has to say its not come back on in X miles return the car to the customer.
The tough world of intermitant fault repairs |
24th Jan 2015 9:24am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Would you have a bill-of-materials that you used for the twin battery install. I have the Bluesea relay and fuse box and I'm trying to make sure I order all the rest of the bits in one go. What size cable did you use..?
Cheers Simon
24th Jan 2015 9:51am |
Evening Simon
No bill as such,, most i had in "stock" anyway To save any hassle, i did order the full kit from Tim at MCL http://www.mobilecentre.co.uk/index.php?ma...cts_id=726 Cable was 50mm for the winch and front Anderson connector Rest is 16 and 35mm all auxiliaries via a 250 amp Durite HD master switch. California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
24th Jan 2015 7:39pm |
No worries, I've looked at Tim's kits so may go that way.
Did you put an isolator in the winch lines..? I have an Albright relay to isolate mine, but wondered if a mechanical isolator was a good idea too. Cheers Simon |
24th Jan 2015 7:48pm |
Top (first) picture, Top left, you can see the HD Isolator
Aux battery feed via isolator to busbar for Winch, Anderson and aux fuse box etc California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
24th Jan 2015 8:08pm |
After being through a few owners, and never fitted, found some time this evening to fit these
Entreq rear Splash Guards Click image to enlarge California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
26th Jan 2015 9:18pm |
Well in total, they did over 150 miles road test. during which they fitted a new 02 sensor, and disconnected the cruise and scangauge ?? Since done 60 odd miles without both, all good,, refitted the scanguage, and another 50/60 and still all good,, then refitted the cruise control, another 80/100 miles, with numerous stop/starts to cycle the system,, and still no light so maybe the 02 sensor that it when in for as being the problem, has cured it ? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
3rd Feb 2015 9:12am |
A downside to the 18" Bowler Alloys,, (or any other with more outset )
Click image to enlarge Click image to enlarge Started off clean,, but 10 miles cross county later !! Needs a mud/splash guard of sorts made between the bottom of the wheel brows and mudflaps, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
10th Feb 2015 6:17pm |
So Plan A
After being pointed to Kevin's Mudstuff site and his DIRT D-FENDER http://www.mudstuff.co.uk/110-dirt-d-fende...nsion.html Ordered Sunday, Arrived today and fitted,, Stainless pan machine screw's rather than the supplied pop rivets Click image to enlarge Click image to enlarge Click image to enlarge That should save the paintwork !! see how long they last ! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
10th Feb 2015 6:20pm |
