![]() | Home > 130 > Rock sliders |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Mine is in for a service tomoz but basically a lug at the front for the bolt that holds the body on (bulk head ) and then a bracket to each of the outriggers
If that's any help Last edited by mick on 21st Jan 2015 10:21pm. Edited 1 time in total |
I've just finished fitting a set on my 90 today. Basically at the rear of the chassis is a tube. The rock slider attachment at the rear is a tube that fits inside the chassis tube and is bolted in place from the opposite side of the chassis with a long bolt and a humoungous washer. The rock slider bolts onto this attachment with two bolts. At the front the rock slider bolts directly to the chassis by means of a 90 degree lug. Not sure what else there is on a 130 but this may help.
http://www.roverparts.com/instructions/Def...9596DF.cfm **EDIT** Found this on the Terrafirma site for a 130. There are pdf instructions on how to fit within the link and it looks the same as a 90 I think. ![]() http://www.terrafirma4x4store.co.uk/defend..._tree_bars If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
blackfly Member Since: 10 Jan 2015 Location: Ghana by way of Ottawa Canada Posts: 8 ![]() ![]() |
Thanks gents,
I'll see what I can work out with the local boys with your feedback. Mick: I'll assume the brackets for the outriggers are bolted on? Did they use preexisting holes or did they need to be drilled? |
epictrail Member Since: 20 Sep 2013 Location: High Wycombe Posts: 395 ![]() ![]() ![]() |
Safari Eqip Versions
http://www.safari-equip.co.uk/shop/index.p...s-130.html ![]() Click image to enlarge ![]() Click image to enlarge |
Mine are same as above all holes already drilled
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 687 ![]() ![]() ![]() |
Mine are below the cills and provide a step.
![]() Click image to enlarge Supplied by Brendan 130 Puma HCPU with an Artica 240LR Demountable Camper |
No tube on a 130 ![]() The ones I made bolt either side of the out riggers and at the font onto the bulkhead to chassis fixing. ![]() Click image to enlarge |
Andrew this is from the Terrafirrma PDF fitting instruction in my link above for the 130 sliders, hence the reason I thought they were similar to mine on my 90:
"Fit the rear support tube into the rear tube body mounting. Push in up to the tube stop and fit M10 bolt spring washer and large washer. Do up finger tight and make sure the square side is at the top." ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
All is clear (ish).
