Home > 130 > Rock sliders
blackfly
Canada
Rock sliders
By chance does anyone have photos of how rock sliders attach to a 130 and if so could they post them?
I'm currently in West Africa, where ordering a set just isn't an option but the local fellows can whip some up. I just want to make sure they're mounted properly as they like to take shortcuts in this part of the world.
Any help greatly appreciated!
Post #391247 21st Jan 2015 10:04pm
mick
Mine is in for a service tomoz but basically a lug at the front for the bolt that holds the body on (bulk head ) and then a bracket to each of the outriggers
If that's any help
Post #391257 21st Jan 2015 10:15pm
K9F
I've just finished fitting a set on my 90 today. Basically at the rear of the chassis is a tube. The rock slider attachment at the rear is a tube that fits inside the chassis tube and is bolted in place from the opposite side of the chassis with a long bolt and a humoungous washer. The rock slider bolts onto this attachment with two bolts. At the front the rock slider bolts directly to the chassis by means of a 90 degree lug. Not sure what else there is on a 130 but this may help.
http://www.roverparts.com/instructions/Def...9596DF.cfm
**EDIT**
Found this on the Terrafirma site for a 130. There are pdf instructions on how to fit within the link and it looks the same as a 90 I think.
Thumbs Up
http://www.terrafirma4x4store.co.uk/defend..._tree_bars If you go through life with your head in the sand....all people will see is an ar5e!!
Post #391258 21st Jan 2015 10:16pm
blackfly
Canada
Thanks gents,
I'll see what I can work out with the local boys with your feedback.
Mick: I'll assume the brackets for the outriggers are bolted on? Did they use preexisting holes or did they need to be drilled?
Post #391470 22nd Jan 2015 1:58pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Safari Eqip Versions
http://www.safari-equip.co.uk/shop/index.p...s-130.html
Post #391475 22nd Jan 2015 2:17pm
mick
Mine are same as above all holes already drilled
Post #391489 22nd Jan 2015 3:31pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mine are below the cills and provide a step.
Supplied by Brendan 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #391493 22nd Jan 2015 3:54pm
AndrewS
No tube on a 130 Thumbs Up
The ones I made bolt either side of the out riggers and at the font onto the bulkhead to chassis fixing.
Post #391582 22nd Jan 2015 8:55pm
K9F
Andrew this is from the Terrafirrma PDF fitting instruction in my link above for the 130 sliders, hence the reason I thought they were similar to mine on my 90:
"Fit the rear support tube into the rear tube body mounting. Push in up to the tube stop and fit M10 bolt spring washer and large washer. Do up finger tight and make sure the square side is at the top."
Question Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #391624 22nd Jan 2015 10:23pm
AndrewS
Thumbs Up I believe you, however they are wrong Thumbs Up
Post #391653 22nd Jan 2015 11:46pm
Anderzander
Post #391679 23rd Jan 2015 8:06am
K9F
All is clear (ish). Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #391684 23rd Jan 2015 8:29am
