Home > Puma (Tdci) > Dealer unable to establish route of water ingress.
Page 2 of 2 <12
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
May be the answer. I like to give everyone the benefit to prove themselves first, but it's maybe time to call in the big guns!
Post #390815 20th Jan 2015 11:02pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Yeah
We approached LR customer service after 4th visit to the dealer and they made the appointment at a different dealer for us. 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #390819 20th Jan 2015 11:15pm
dnorrishill
England 2014 Defender 90 Puma 2.2 XS CSW Aintree Green
I have found that defenders can leak or not depending on whether they are leaning to one side or the other.
Is it possible that your drive or where ever it leaks is on a slope and the LR test is on the flat or vice versa?
Post #390837 20th Jan 2015 11:50pm
borderterrier
My drive is as flat as a witches tit! The idea of the rig they use is to force water in at various angles. No sure whether they angle the vehicle when testing, burnt doubt it!
Post #390841 20th Jan 2015 11:55pm
mk1collector
If the screen has been out I'd take it to auto windscreens or someone similar and just get them to take it out again and re-seal then it might get done properly.
Post #390844 21st Jan 2015 12:09am
Busboy
Mines in at the moment for the same leaks, although out of warranty LR are willing to cover 80% of the bill as a good will gesture Razz so we will see.......if all is cured.. Steve
Post #390870 21st Jan 2015 8:34am
K9F
MK1collector is bang on the nail. If when the screen came out it wasn't resealed correctly especially if they didn't replace the seal with the old sealant on, pound to a pinch that'll be where your problem lies. Also with a heated screen when I had the same issues it can be hard to get them to willingly take the screen out as with a heated one there is a risk of damage each time it is removed and refitted to the element. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #390879 21st Jan 2015 9:11am
What dealer is it?
Post #390931 21st Jan 2015 10:54am
borderterrier
Its TH White in Wooten Bassett. Just collected the truck and was told that LR only authorise 3 hrs labour to find a leak thereafter its dealers discretion. Mine has had 9 hrs of attention. Think I am going to get in touch with LR Customer Services.
Post #390956 21st Jan 2015 11:33am
My last 110 (bought from Whites), they took the whole roof off and re-sealed it. must have taken more than 9 hours.
Get customer services to intervene.
Post #390964 21st Jan 2015 11:50am
borderterrier
That's 9 hrs looking for the leak! Anyone got Customer Services number?
Post #390966 21st Jan 2015 11:53am
steve E
Wales
Ask Ryan for help on here.
they've been great with sorting problems out for memebers on this site.
Post #390970 21st Jan 2015 12:03pm
borderterrier
I prefer face to face and in it's absence a phone call. If I get no joy I will try Ryan.
Post #390982 21st Jan 2015 12:16pm
smb
Mine went back 4 times, a total of 6 weeks, and each time it was given back to me supposedly sorted it leaked worse. It cost me far too much time pi55ing about back and forth and in the end I got Autoglass to come and replace a chipped windscreen. Turned out the Autoglass guy was a Defender enthusiast who knew exactly where and how to sort it. No problem since, until it went in for final warranty work on corrosion and then it started leaking again. Turned out they had taken the windscreen out and because they cracked it in doing so had to replace it.
Im not saying all do as there are some good ones(a rarity though), but a lot of the problems are caused by the dealers and their bodyshops trying to cut corners/not knowing what they are doing/rushing/etc....
Post #391049 21st Jan 2015 3:18pm
Page 2 of 2 <12
