Home > Puma (Tdci) > Dealer unable to establish route of water ingress.
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Post #390731 20th Jan 2015 8:14pm
JAY BOY
Wales
I would contact LR customer services. They have always been very good with my problems.
You may need to lay down the law with them and that you have bought a product that is unfit for purpose. You shouldn't expect that a these days a car can be produced that has a pond internally.
I have one in mine and will get them to sort it when the weather picks up.
Good luck. Thumbs Up
Post #390736 20th Jan 2015 8:28pm
Cuthbert
I'd ask the dealer to put in writing that they are unable to resolve this issue ......... then the fun begins!
Post #390780 20th Jan 2015 9:20pm
Windowlicker
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
Just out of interest, do you end up with a puddle on the floor matt, inline/in front of the throttle pedal?
Cheers,
Nick "Procrastination is the thief of time"
Post #390784 20th Jan 2015 9:23pm
borderterrier
Yep, I mentioned that when I spoke to them. I always get copies of warranty work and this will be no exception.
Post #390787 20th Jan 2015 9:26pm
borderterrier
Cheers,
Nick
The whole angled upright of the footwell is soaked, impossible to nail a puddle to any specific position mate.
Post #390788 20th Jan 2015 9:28pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
LR water spray machine= lad with a hose Whistle 2005 Td5 90 XS
Steve
Post #390790 20th Jan 2015 9:29pm
Pipmac
United Kingdom 2014 Defender 90 Puma 2.2 SW Keswick Green
Hello there, I have the same in my 2014. Rusty water dripping from the tunnel side of the drivers footwell. Haven't had a chance to take it in yet. Doesn't look like much volume wise but leaves rusty trail on the rubber flooring, so easier to see than on carpet. Will try to get a photo uploaded at the weekend.
Post #390793 20th Jan 2015 9:30pm
borderterrier
This was a jig wih water jets that can be angled and the water pressure adjusted.
Post #390796 20th Jan 2015 9:32pm
Windowlicker
Ah, ok, mine would leak down the r/h side of the bulkhead, drop out of the plastic above the door check strap, fill the alloy check strap, pool up then when full , it would run out and form a big puddle on the matt.
Having removed the windscreen ( dummy hinge) brackets, cleaned them up, made new gaskets, sealed etc, I was supremely peed off to find it had no effect.
After a heavy shower, by chance , whilst poking about , I lifted the corner of the windscreen seal, and It quite literally ran out from that point.
It would appear the seal, was actually holding water , it would gather at that point as I park on a slight angle, it would fill up and then run through, under the glass and leak into the car.
I put a small piece of tie wrap up under that corner, to lift the feather edge of the rubber seal away from the panel, and it has been bone dry ever since.
Maybe after another heavy shower, it might be worth just lifting the bottom edge of the seal up and seeing if anything runs out.
Cheers,
Nick. "Procrastination is the thief of time"
Post #390798 20th Jan 2015 9:38pm
JAY BOY
Wales
Mine passenger side Big Cry
Post #390800 20th Jan 2015 9:38pm
borderterrier
Post #390804 20th Jan 2015 9:49pm
RobKeay
My last 90!had a terrible leak. Smashed the windscreen, had a new one fitted and sealed resulted in no leak. My local dealer had had the roof off and had tried but in the end auto windscreens fixed the problem.
Post #390808 20th Jan 2015 9:51pm
Just what is the meaning of under warranty if they try and make you collect the vehicle unfixed? I wasn't aware of a time limit - imagine if this applied to an oil leak or any other repair!
I'd be asking the dealer politely to escalate to LR direct.
Post #390809 20th Jan 2015 9:51pm
NickH
England 2003 Defender 90 Td5 PU Rimini Red
Had exactly the same with our 12 plate 110
Dealer had it 3 times and couldnt find it, 4 th time they had it 2 weeks and took the roof off ! still leaked.
Took it to another dealer , they had it half a day and fixed it.......shame they got sikaflex everywhere and it had to go back for it cleaning off Rolling Eyes
Change dealers Thumbs Up 2003 Td5 90
2013 sport hse
2012 700 raptor quad
2012 siromer 4x4 tractor
Post #390812 20th Jan 2015 9:59pm
