Home > My Defender > Defender 110 XS No5 2015MY
Page 7 of 11 <123 ... 678 91011>
bell-auto-services
Yes, I have fitted a few new engine ecus and sensors for the same fault, but of course Landrover being Landrover will extinguish every other possibility before even contemplating a PCM fault which sometimes causes delay in the repair I think which does not help.
Providing they have done the correct checks on the sensor its self OR swapped it from another car to yours as a test AND checked the wiring back to the ecu and all is ok then id strongly suspect a failed PCM.
Note the MIL activation is only after 3 cycles and so they do need to start and stop the engine a few times, re read the dtc's and seeif the fault is backor not irespective of if the mil in lit at that point or not.
They seem not to have done the latter and that will explain why the mil came back on when you took the car away.
Pete
Post #390565 20th Jan 2015 3:16pm
TJ101
Thanks Pete Bow down
We are currently in the
mode at present,,
A word in their shell like i believe is in order Idea California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #390578 20th Jan 2015 3:44pm
bell-auto-services
No problem.
Im sure they will get their in the end and it may not turn out to be the pcm afterall but time will tell I suppose.
Pete
Post #390581 20th Jan 2015 3:57pm
Stiff1
TJ101 wrote:
Stiff1 wrote:
Apologies if mentioned, what tint is that you have, looks just right.
All bar the rear tailgate glass,(as LR do not do that one Shocked ) is as per the factory supplied/fitted option One ? maybe 2 shades lighter than limo
Thanks.
Post #390851 20th Jan 2015 11:44pm
TJ101
bell-auto-services wrote:
No problem.
Pete
FYI Pete
A new sensor did not cure it Rolling Eyes California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391079 21st Jan 2015 4:33pm
Xelr8
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Sounds like our vehicles are having the same problems. Rolling Eyes
Bowlers have fixed it but after your comments above I've asked them to go on an extended drive to see if the Light stays off.
This is happening tomorrow so I'll report back with the results.
Leon
Post #391083 21st Jan 2015 4:57pm
TJ101
Thanks for that Leon,, Interesting !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391084 21st Jan 2015 5:01pm
BigRuss
Still glad you chopped No. 4 in Tim? Russell
2011MY 110 XS USW Black
Post #391086 21st Jan 2015 5:12pm
TJ101
Big Cry not at present, Russ,, but sure its only a teething problem !! Shocked
I have No4, as a back up Very Happy Thumbs Up California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391091 21st Jan 2015 5:27pm
walfy
I'm having the same issues. I reported a fault within 2 weeks of ownership. Been in 3 times for other bits and I kept reporting the same fault. Only to be told everytime they couldn't replicate my symptoms.
Well it went in today for issues with the central locking and alarm. Reported the problem again. Call today to say car is ready for collection. But we need to order parts for the central locking and some other bits. Your original problem has been identified and we need a working week to fix it. So it's booked back in next month. If only they'd of listened to me 12 months ago. 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #391130 21st Jan 2015 6:52pm
TJ101
Same codes Mark ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391335 22nd Jan 2015 8:06am
TJ101
Its would seam they are now trying to lay the blame at the Scangauge Shocked Rolling with laughter California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #391467 22nd Jan 2015 1:50pm
I see their logic..... if you didn't have the scanguage, you wouldn't know about the error codes, thus, fault of the scanguage Rolling with laughter Rolling with laughter
Post #391472 22nd Jan 2015 2:09pm
walfy
Not same fault Tim, but same issue in the fact LR denying my issue existed and blaming also rats and then the typical line, they all do that. 110 D250 SE HT
110 USW SOLD
Post #391502 22nd Jan 2015 5:02pm
bell-auto-services
Shame the sensor didn't fix it Sad
Is seems one of those faults that can in some cases be quite hard to replicate as the problem is not always seen/happens in every engine cycle which does not help especially when the garage is trying to fmd a cure or fix.
Pete.
Post #391628 22nd Jan 2015 10:34pm
