Home > In Car Electronics > Electrical Gremlins Td5 |
Have you checked earths and fuses?
16th Jan 2015 12:18pm |
boode Member Since: 11 Apr 2012 Location: Devon Posts: 430 |
Fuses all OK
Edit - the Black/white wire that feeds the rear demist relay should be live but is not (it was live yesterday when only the rear demist was not working) So I think I have a live current problem which is affecting the lights, gauges etc All points seem to be earthing OK Anybody know where this Black/white wire originates from - it goes up behind the dash and is lost in the thick loom. Checked all yellow relays - in fuse box and under drivers seat - all seem OK |
16th Jan 2015 12:39pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2237 |
Check the wiring in the rubber grommet/tube running to the rear door. Bet the demist one is snapped, wouldnt mind betting the others (wiper and brake light) arnt far behind.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
16th Jan 2015 4:43pm |
All sorted
Loose wire behind a 5amp fuse (no headlights, speedo, warning dash lights) and a broken wire going into the rear door (demist) - thanks rallysteve Just need to rebuild it all tomorrow |
16th Jan 2015 6:41pm |
