Home > In Car Electronics > Electrical Gremlins Td5
boode
England 2003 Defender 90 Td5 HT Rutland Red
I have lost rear demist, rear fog light and main headlights (but they still work on flash)
Edit - Just realised that Speedo, Fuel and Temp gauges are also dead
Orange dash light on demist was working and relay was clicking but no power to rear screen
Now dash light also dead on demist and rear fog switch
Any ideas ?
Post #388960 16th Jan 2015 9:54am
mk1collector
Have you checked earths and fuses?
Post #389021 16th Jan 2015 12:18pm
boode
Fuses all OK
Edit - the Black/white wire that feeds the rear demist relay should be live but is not
(it was live yesterday when only the rear demist was not working)
So I think I have a live current problem which is affecting the lights, gauges etc
All points seem to be earthing OK
Anybody know where this Black/white wire originates from - it goes up behind the dash and is lost in the thick loom.
Checked all yellow relays - in fuse box and under drivers seat - all seem OK
Post #389022 16th Jan 2015 12:39pm
rallysteve
Check the wiring in the rubber grommet/tube running to the rear door. Bet the demist one is snapped, wouldnt mind betting the others (wiper and brake light) arnt far behind.
Post #389080 16th Jan 2015 4:43pm
boode
All sorted
Loose wire behind a 5amp fuse (no headlights, speedo, warning dash lights) and a broken wire going into the rear door (demist) - thanks rallysteve
Just need to rebuild it all tomorrow
Post #389141 16th Jan 2015 6:41pm
