![]() | Home > Puma (Tdci) > Diff (front and rear) oil change |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
Why all of you are changing earlier from what LR recomends?
Severe conditions? Lot of mud and water crossings?? regards. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2469 ![]() ![]() ![]() |
yes, severe conditions: heat, towing, muddy, dusty, wadding etc
Synthetic oils oils long last. Puma 110" SW ............................................................. Earth first. Other planets later |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5093 ![]() ![]() ![]() |
Swivels should not be fully filled - the one shot grease does not fully fill them. Mike |
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
I don't think the filler allows you to pack the joint 100% full as it is at about 2'o clock position in relation to the full position.
The reason I filled them is because I found a lot of grease emulsion in the front diff oil and I noticed the swivels were slightly drier than usual so I rather overfill than too little. My reasoning is it shouldn't do any harm as when it gets warm, all that should happen is the air above the grease level under slighly more pressure will escape the seals and suck in air when it cools again. Haven't noticed any ill effect over the last month since I did it. |
YES never overfilled. When hot the grease (or the oil) increase its volume and you can have blowing effects... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
