Home > Puma (Tdci) > Diff (front and rear) oil change
Page 2 of 4 <1234>
mse
MK wrote:
mse wrote:
Am i missing something Grease for life should be in the swivels and therefore they shouldnt need to be drained and thus only checked through the top plug (there should be a rear drain one)
As for the diff oil...i wonder
THey are supposed to be greased/sealed for "life". I was just mentioning the above in case of water contamination. The only plug is to fill in with one shot grease (#STC3435) which is about 350 cc.
if there is water in there you want to strip it down anyway Mike
Post #18572 18th Nov 2009 9:31pm
CapeLandy
South Africa
So are we supposed to use the Castrol Full Synthetic Oil in the two diffs as opposed to the EP 80W 90 from the manual?
My Castrol agent down the road said the synthetic is better but would that be overkill? Puma 110 - gone
Series III 1973 - going strong
Post #18592 19th Nov 2009 11:45am
dgardel
Italy
No overkill.... Wink Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18593 19th Nov 2009 11:57am
CapeLandy
South Africa
Thanks Dgardle
one more question. In RSA Castrol only have the BOT 130M which is a GL4 (75W80)
- will this still be OK?
For interest I called LR parts who would not give the specification but told me I could only get the oil from them at a cost of ZAR 369 per liter as opposed to Castrol who charge it at ZAR 79 per liter. Shocked Puma 110 - gone
Post #18623 19th Nov 2009 3:24pm
MK
You have to use GL-4 in the gearbox. Sulphur and other stuff would kill any yellow metal (bronze and other alloys). Puma 110" SW
Post #18625 19th Nov 2009 4:30pm
dgardel
Italy
CapeLandy wrote:
Thanks Dgardle
BOT130M it's ok, is the predecessor of 328 (in Italy at least....) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18639 19th Nov 2009 8:42pm
CapeLandy
South Africa
Still Confused
I still am confused somewhat
On further investigation:
The TexacoEP-C 80W-90 (listed as diff oil in user manual) has very similar specs to the Castrol EPX 80W-90 API GL-5 as below:
Texaco
Density at 15'C 898kg/m^3
Viscosity 100'C 14.5
Viscosity 40'C 131
Brookfield Viscosity @-26'C 130,000
Pour Point -33
Castrol EPX
886
14.2
140.3
130,000
-30
BOT130M
873
15.1
76
3400
-54
Seems EPX has closer readings so won't be detrimental?
Anyways, I dropped the oil in both diffs. Front was very black with slight water emulsion and seemed a little greasy. Must check swivel housing levels tomorrow. Rear diff little brown but not nearly as bad as front.
I refilled with the EPX as above until someone advises me I made big mistake or not.
Cheers 4 now Puma 110 - gone
Post #18689 20th Nov 2009 9:48pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Castrol EPX 80W-90 is what we use in Australia. You could also use Castrol Syntrax (as in the Transfer case). It's a full synthetic and handles higher temperatures better. Over here its also twice the price of EPX, so I just use it in the Transfer case. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18691 20th Nov 2009 10:08pm
CapeLandy
South Africa
Thanks Derek, feel little more confident now.
Will replace with Syntrax at next big trip into hot dusty Africa.
(June 2010 when all the football hooligans arrive Wink ) Puma 110 - gone
Post #18692 20th Nov 2009 10:26pm
MK
Re: Still Confused
Texaco
Viscosity 40'C 131
Pour Point -33
Castrol EPX
886
14.2
140.3
130,000
-30
BOT130M
873
15.1
76
3400
-54
Cheers 4 now
Capelandy:
I think you can not check the swivels. They filled with 370 gm of grease.
MK Puma 110" SW
Post #18699 21st Nov 2009 1:45am
CapeLandy
South Africa
I wanted to stick my finger down the filler hole and check the level.
If EP0 is fairly runny then it should leave a level of sorts that you could feel with a thin pinkie finger - or not? Puma 110 - gone
Post #18701 21st Nov 2009 6:33am
dm_td5
I can just see the headline: Cape Town man traps digit in Land Rover Laughing
What about using a small, clean screw driver. As long as it can't fall entirely through the hole it might be better. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #18702 21st Nov 2009 8:05am
dgardel
Italy
no way to check with finger
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #18709 21st Nov 2009 12:29pm
CapeLandy
South Africa
Another thing to note, when I removed both filler plugs on the front and rear diffs and buffed the threads in the wire buff to remove the old thread sealant, I noticed both threads were stripped/ damaged. Evil or Very Mad
Seems the filler socket/insert is welded into the diff housing which causes the thread to shrink. Normally one needs to run a tap through again after welding in such a thin socket. They must have then forced in the filler plug in the factory, damaging the threads. The drains were ok however.
Anyways, ran a thread file over them a little but not much to salvage.
I fitted a light layer of hydraulic thread sealer on the threads before refitting.
Amazing that this can be happening in the factory. I assume Puma 110 - gone
Post #18715 21st Nov 2009 3:21pm
Grockle
doesn't bear thinking about the bodged stuff you don't find whilst doing maitenance Crying or Very sad 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #18716 21st Nov 2009 3:45pm
Page 2 of 4 <1234>
