Home > Maintenance & Modifications > Body wrapping Defender 90 |
Shutts Member Since: 10 Aug 2014 Location: Tiptree Posts: 52 |
Recently I bought a 90 for green laning and as a project to work on in the little spare time I have. The paint work needs a bit of attention and I would like to change the colour as there are various different coloured panels on her at the moment. However, I don't want pay a fortune on a complete respray just to scratch it up taking it through hedges and trees.
Based on this I was considering using a body wrap as I have heard good things about them. Has anyone had any experience with them, and if so would you recommend a brand or type. Also what is the rough cost and is it something you can do yourself or should you go to a specialist company. Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip |
14th Jan 2015 10:36pm |
smb Member Since: 15 Jan 2013 Location: Cheshire Posts: 1232 |
Send a PM to Ellebarto. I don't know whether he still has it on, but it looked a good job
14th Jan 2015 11:57pm |
paulnb57 Member Since: 18 May 2011 Location: Isle of Wight UK Posts: 38 |
Ellbarto removed it....
15th Jan 2015 6:56am |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
If it was me Id do like JimBob said get it nicely rubbed down and remove/ mask up as much as you can. As your local get a big can of Nato green or sand from Witham SV or your local paint supplier and brush/ roll it. Youll get a good enough finish for a land rover easily Defender puma dormobile camper
15th Jan 2015 8:37am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
I am trying to make my 90 one color too, but driving it has higher priority. I roll it with cheap paint. for less then 50 pounds I think I will have the 90 in one color. I am afraid however that parts might be damaged before it is painted completely.
Click image to enlarge Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
15th Jan 2015 8:42am |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
FTW! Pov.spec,ftw. 2006, 110,TD5. |
15th Jan 2015 1:30pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2270 |
Coach paint from Turners, will last well, is designed to be brushable and rollable and they will mix whatever colour you want. Doesn't come out concours but reasonable finish and you won't cry when you drag it down a hedge mines been on 4 years now and just gets an annual touch up.
15th Jan 2015 1:54pm |
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 |
I used Dulux glosson a van once, came out quite well! 2.2 90 XS
88" Series One Old Norton Minerva |
15th Jan 2015 4:22pm |
Sounds like a plan guys, a roller it will be when the time comes.
15th Jan 2015 5:02pm |
Roller painting is always a winner. My ibex, before and after.
15th Jan 2015 8:13pm |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 |
U pol raptor!
15th Jan 2015 8:57pm |
Hey Roel, where did you get roll cage that only covers the drivers side of the car? Shutts |____000_ [l_|__\___\,___ l--___--_[O==O] ()_)' '()_)-----()_) 2005 D3 SE 1998 Disco 300tdi - slow play thing 1995 Defender 300tdi - Winching play thing Aprilia RSV 1000 - fast play thing Honda CR250 - noisy play thing Essex Land Rover Club member ------- Andy's Landy's - http://www.andys-landys.blogspot.com Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip Last edited by Shutts on 16th Jan 2015 12:02am. Edited 1 time in total |
15th Jan 2015 10:29pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 |
I think top is pre fitting and below post fitting a rear only hoop as I can't see it through the window. Could be wrong though! Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
15th Jan 2015 11:08pm |
Shaggydog, added a smiley now just to say I was joking |____000_
16th Jan 2015 12:04am |
