Home > Maintenance & Modifications > Fitting interior light into back of 110 Hard Top
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
I've got a 110 van and could do with a light in the back to help see what I'm doing in there. Is there a genuine Land Rover option for this, or is it something that has to be sorted with aftermarket parts? Its absence wasn't something I was aware of when I bought it last year.
I've had a search and didn't see anything (sorry if I've missed it), so any help or suggestions would be much appreciated.
Thanks folks.
Post #386497 8th Jan 2015 8:10pm
Macpaul
United Kingdom 2013 Defender 110 Puma 2.2 USW Loire Blue
I had two led strips fitted (one on each side) to the rear of my hardtop by Ian at IRB which probably means they came from Tim at Mobilecentre.
They're about 500 long and give a terrific amount of light. Highly recommended. 2003 Td5 110 Hardtop
Now a 2013 110 USW too.
Post #386573 8th Jan 2015 10:14pm
Macpaul
Yup, here it is
http://www.mobilecentre.co.uk/index.php?ma...ath=10_192 2003 Td5 110 Hardtop
Post #386587 8th Jan 2015 10:26pm
Cupboard
I've been eyeing up this:
http://www.mudstuff.co.uk/labcraft-nebula-s15-led-lamp.html
Does your rear door have a switch or anything to turn a light on when it opens? Mine doesn't, but then the rear door is a bit battered.
Post #386600 8th Jan 2015 10:55pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I bought a roll of LED strip lights off eBay and used it either side in the rear of my 90. It's brilliant compared to the glow worm standard light.
Self adhesive too, so easy to fit.
http://www.ebay.co.uk/itm/5M-Led-Strip-12V...hash=item0
Simon
Post #386622 8th Jan 2015 11:35pm
Macpaul
Yes, mine's connected to the plunger door switch so it operates when the door opens/closes.
The plunger switch fits to a bracket on the hinge side of the door that you probably do have, and the switch itself is only a few quid. 2003 Td5 110 Hardtop
Post #386644 9th Jan 2015 5:48am
Nidge
Ireland 2009 Defender 110 Puma 2.4 HCPU Cairns Blue
Joe I fit one of these to the back of the Hard top...draws low current...find it great.
http://www.mudstuff.co.uk/products/electri...touch.html
I just wired it up to the purple wire behind the rear light panel, which means its always live, good light out of it too.
N.
Post #386663 9th Jan 2015 8:50am
Joe the Plumber
Thanks very much folks, this is all very helpful. I'll let you know where I end up.
Post #386715 9th Jan 2015 12:59pm
Joe the Plumber
Dredging up my ancient topic, I've finally just bought one of these (no point in rushing these things...) :-
http://www.ebay.co.uk/itm/221441707072?_tr...EBIDX%3AIT
It's the same one as Mud UK sell, but was nine quid less, delivered, and like Mud UK, H. Bowers are another great firm to deal with (they supplied the diesel heater kit for our narrow boat) and delivered it in two days, in spite of it being Christmas.
All I've got to do now is actually fit it. The purple wire to my rear door switch looks a good bet for the live feed, but my bodywork is not making a good enough earth connection (the light is very dim using it) so I think I'll need to run an earth wire to it from somewhere else (any suggestions most welcome, incidentally).
Post #587212 23rd Dec 2016 4:11pm
jst
i fitted similar to these http://www.lightingever.co.uk/12v-led-stri...GwodLaoLEw
in the back of my USW along the top trim next to the headlining, ran them off a switch above the speaker inside the door on the RHS. took the feed from the purple perm live there. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #587411 24th Dec 2016 4:49pm
Joe the Plumber
Just to bring this up to date, I fitted the new lamp over Christmas, eventually joining into the two wires that go to the plug on my front interior lamp to feed it. It wasn't too difficult once I'd managed to run the wires to it above the headlining in the cab.
I have to say the result is absolutely fantastic. It's like daylight in the back now with it switched on.
Post #590702 6th Jan 2017 2:06pm
Joe the Plumber
Sorry James, I meant to say thanks for your post in reply to my previous one.
Post #590704 6th Jan 2017 2:08pm
jst
Thumbs Up Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #590790 6th Jan 2017 6:22pm
