![]() | Home > Maintenance & Modifications > Rear door gas strut again |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1126 ![]() ![]() |
I too have just fitted this kit, and find it great. The only thing I would say is it does tend to throw the door open quite hard, and does not have any damping at the end of the travel, this means the door swings fully open against the limit of travel in the strut. It puts a lot of strain on the body mounting. Best to catch the door and slow it down a little as it opens.
Great mod though, and really does hold the door open whilst working from the rear of the car. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
IanW Member Since: 12 Jun 2011 Location: Gloucestershire Posts: 172 ![]() ![]() ![]() |
I fitted the Mudstuff one, also �75, last weekend, which looks identical to the earlier pics. With non standard lights or a larger wheel the positioning of the rivets is pretty crucial to control how far the door swings out, but my standard setup not too difficult. On short acquaintance well worth the 75 quid. One wife - livid
When the gas struts are new they can be a bit keen. We suggest that people control the opening of the rear door by just placing a hand on it as it opens rather then letting the door bang against the gas strut limit.
These gas struts can be ordered here We will have some at Peterborough if you want to save postage and if you preorder them you might even get a small discount ![]() Brendan |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
I've just ordered mine from your site Brendan
Or use the LR light guard as a bump-stop - it ends up at a strange angle but does the job: ![]() Click image to enlarge :lol: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
AlexSmith Member Since: 05 Sep 2013 Location: Arroio do Meio, RS Posts: 47 ![]() ![]() ![]() |
Can someone post a picture of the gas strut tag, so that it is possible to see its specs? I'm looking for the strenght (in Newtons), so that I can do it with a similar strut here. Thanks! 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray 2002-2005: Defender 90 CSW 300 Tdi Dark Green |
stu_007 Member Since: 23 Jan 2014 Location: Cardiff Posts: 99 ![]() ![]() |
I've just fitted one of these and as people have said it does open quite fast! I'm a little concerned as I can see the wheel box flexing where the end of the srut connects with the body work via the new bracket and am a little concern the metal could "tear" over time.... any helpful comments/ suggestions? Current
2021 D110 HSE 2013 D90 XS Previous BP07 OZR D110 (1930 YBA) 2007 G4 Mongolian Recce Vehicle BP52GHZ D110 2003 & 2006 G4 Event Vehicle |
really there to hold the door open , you need to still have a hold on the door and let it back slowly
Thanks. Did think this but even doing this you can see wheel box flexing! Current
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20730 ![]() ![]() |
It won't flex if you put a larger metal plate infront of it to spread the load.
A bit like a sandwiched washer only square. |
Yes can see that but just wondering why mine is doing this when no-one else has this issue. I'll take it apart again and loosen things off again. I can also not find anything mentioning where to put the washers that came with kit( I just put them under nylock nuts? Current
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1646 ![]() ![]() |
I've had the Mudstuff one for a good while now and it's a great mod the flexing is normal and it's not broken yet and I run a big swing away carrier off the door as well
I fitted a gas strut to my last Puma and took it off before trading the vehicle in but have probably decided against fitting it to the new vehicle. The reason for the decision is that I got a bit fed up preventing the open door being pushed against the jockey wheel or handbrake on my trailers. Ok it's no big problem to keep a bit of cloth or something handy to stuff between the door and trailer to stop damage but catching the door and remembering to stick something in it each and every time just became a chore.
So the strut, bracket along with the 2.4 Adrenaline pedal lock which doesn't fit a 2.2 is likely to sit on the shelf gathering dust ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 ![]() ![]() ![]() |
[quote Miserableolgit]The reason for the decision is that I got a bit fed up preventing the open door being pushed against the jockey wheel or handbrake on my trailers[/quote]
Good point Steve Only had a damper on the new one, and not towed as yet, but i can see this may be a problem, with other people using the rear door !! so may only have it fitted for longer overseas trips and coming off for other times ! Re the wheel box panel flex, fitted mine with spreader plates,, California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
