Home > Maintenance & Modifications > Rear door gas strut again
Page 4 of 4 <1234
stu_007
Plates behind the wheel box or in front, behind bracket? Current
2021 D110 HSE
2013 D90 XS
Previous
BP07 OZR D110 (1930 YBA)
2007 G4 Mongolian Recce Vehicle
BP52GHZ D110
2003 & 2006 G4 Event Vehicle
Post #383717 31st Dec 2014 7:56pm
Mountain_man
Wales
AlexSmith wrote:
Can someone post a picture of the gas strut tag, so that it is possible to see its specs? I'm looking for the strenght (in Newtons), so that I can do it with a similar strut here. Thanks!
Hi Alex
I did this myself as a project with an off the shelf strut. I did the calculations based on the recommendations of the manufacturer and ordered what I thought would be the ideal strut for a door with a spare wheel mounted. It is just about ideal, but as others have said it is necessary to slow it a little at the end of the stroke or it can give a big jerk to the mountings.
Spec of the strut I ordered was
L 407.5, stroke 160mm, Force 400N with 8.1mm clevis/clevis ends
Part No. 016 25029/400
From this company
http://www.suspa.com/uk
My Mk1 fitting. There is a slightly larger spreader plat on the other side of the wheel arch.
Post #383719 31st Dec 2014 8:01pm
Mountain_man
Wales
I find that on all my trailers the spare tyre on the door catches the jockey wheel so there is little risk of paint damage unless I am parked at a strange angle
Post #383720 31st Dec 2014 8:04pm
AlexSmith
Brazil 2004 Defender 110 300 Tdi SW Alpine White
That's awesome! Where is the "Thanks" button? Smile
Anyway, thank you very much! Exactly what I needed!
I'll post pictures as soon as I get it done.
Alex.
Mountain_man wrote:
Hi Alex
From this company
 2020: Defender 110 SW 300 Tdi 2004 Alpine White
2013-2017: Defender 110 S 2.4 (Puma) 2008 Stornoway Gray
2002-2005: Defender 90 CSW 300 Tdi Dark Green
Post #383925 1st Jan 2015 4:11pm
leeds
There is more to gas struts then force and lengths.
The ones used in the Mk 2 version are a special order gas strut. Currently we can not get any more rear door gas struts until mid February time when the next batch of gas struts comes off the production line. Hopefully we will have enough Mk2 versions to last us through until we can get more.
Brendan
Post #383929 1st Jan 2015 4:49pm
Happyoldgit
As I said that was not the case with mine so it's wise to be cautious when opening the door for the first time if you have a trailer in tow, with a bit of luck you'll be ok Thumbs Up Steve.
http://forums.lr4x4.com
Post #383956 1st Jan 2015 7:06pm
Page 4 of 4 <1234
