![]() | Home > Technical > Puma Heated Windscreen Switch Wiring |
![]() Click image to enlarge this may help Pin 1 - from Timer Relay Pin 2 - Live from Dash Illumination Pin 3 - Not Used (but internally connected to Pin 4) Pin 4 - To Earth Pin 5 - Live from output side of Relay (to light the tell-tale LED) |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 508 ![]() ![]() ![]() |
On the switch pins -
Pin 1 - From heated front screen timer (terminal 5) Pin 2 - Dash illumination live Pin 3 - Not used Pin 4 - Earth Pin 5 - Live from heated front screen relay (terminal 87) - to illuminate switch's tell-tale LED It's a momentary switch, which switches terminal 5 of the heated front screen timer to earth. This starts the timer's timed period. This diagram is for the 2002 TD5 Defender - but, the circuit is the same as the Tdci Defender - ![]() Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' Last edited by PaulMc on 25th Dec 2014 8:48pm. Edited 1 time in total |
That diagram shows a switch that's been internally modified to be a live-switching switch. It's shown being used with an after-market timer relay, which requires a live pulse to start its timed period. The switch pinouts detailed below the diagram, are for the un-modified switch, used with the OE timer relay (PRC6796) . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Smudger Member Since: 26 Nov 2012 Location: Basingstoke Posts: 36 ![]() ![]() ![]() |
Thanks guys, I've all the info I need now.
S 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
defender_uk Member Since: 12 Aug 2011 Location: SW Scotland Posts: 197 ![]() ![]() |
is the wiring there in all new defenders, just not wired up?
really want to get one in the new 90... thanks 2020 First Ed 110. replaced by 2021 250 110 Commercial Defender_uk |
paul your right switch has been pos switching mod
Guys,
Well I am confused! I spent the day finishing this off and I can't get it to work. I know I've got the high current relay in properly. I'm using OE PRC6796 and an OE switch any clues please? S 08 110 Puma Station Wagon 65 Jaguar XF Sportbrake S 99 Elise 111S Honda XR250 42 Royal Enfield Flying Flea 43 Matchless G3L |
Stand down I sorted it. Thanks all the same.
