Home > Technical > Puma Heated Windscreen Switch Wiring
Smudger
United Kingdom 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Happy Christmas All,
Anyone got the pin outs for the OE Puma Heated Windscreen Switch to hand?
s 08 110 Puma Station Wagon
65 Jaguar XF Sportbrake S
99 Elise 111S
Honda XR250
42 Royal Enfield Flying Flea
43 Matchless G3L
Post #381838 25th Dec 2014 7:32pm
dorsetsmith
this may help
Pin 1 - from Timer Relay
Pin 2 - Live from Dash Illumination
Pin 3 - Not Used (but internally connected to Pin 4)
Pin 4 - To Earth
Pin 5 - Live from output side of Relay (to light the tell-tale LED)
Post #381855 25th Dec 2014 8:24pm
PaulMc
On the switch pins -
Pin 1 - From heated front screen timer (terminal 5)
Pin 2 - Dash illumination live
Pin 3 - Not used
Pin 4 - Earth
Pin 5 - Live from heated front screen relay (terminal 87) - to illuminate switch's tell-tale LED
It's a momentary switch, which switches terminal 5 of the heated front screen timer to earth. This starts the timer's timed period.
This diagram is for the 2002 TD5 Defender - but, the circuit is the same as the Tdci Defender -
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #381857 25th Dec 2014 8:37pm
PaulMc
dorsetsmith wrote:
this may help
Pin 4 - To Earth
That diagram shows a switch that's been internally modified to be a live-switching switch.
It's shown being used with an after-market timer relay, which requires a live pulse to start its timed period.
The switch pinouts detailed below the diagram, are for the un-modified switch, used with the OE timer relay (PRC6796)
. Paul.
Post #381860 25th Dec 2014 8:42pm
Smudger
Thanks guys, I've all the info I need now.
S 08 110 Puma Station Wagon
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #381862 25th Dec 2014 8:52pm
defender_uk
is the wiring there in all new defenders, just not wired up?
really want to get one in the new 90...
thanks 2020 First Ed 110.
replaced by 2021 250 110 Commercial
Defender_uk
Post #381868 25th Dec 2014 9:15pm
dorsetsmith
paul your right switch has been pos switching mod Exclamation
PaulMc wrote:
dorsetsmith wrote:
this may help
Pin 4 - To Earth
Post #381922 26th Dec 2014 9:35am
Smudger
Guys,
Well I am confused! I spent the day finishing this off and I can't get it to work. I know I've got the high current relay in properly. I'm using OE PRC6796 and an OE switch any clues please?
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #475506 23rd Nov 2015 7:10pm
Smudger
Stand down I sorted it. Thanks all the same.
99 Elise 111S
Honda XR250
43 Matchless G3L
Post #475536 23rd Nov 2015 7:35pm
