Home > Technical > 3rd Brake Light Issue and......
CatherineF
Ok fabulous people of Defender2, is there a connection here?????
As you know I mentioned the rear 3rd brake light wasn't working, but today we needed to defrost the rear screen. All appears to be working except for the elements that surround the 3rd brake light.
Do you think this is just a coincidence or does this point out an issue that you chaps in the know now can say "Oh yes it's this....."
Catherine
Post #379356 16th Dec 2014 8:30am
K9F
Catherine this is a very common occurence in earlier Pumas. By removing the shroud that covers the rear brake light you will see where it will have worn through the element. I'll update this with a few links. Latter models have an element that routes around the brake light. You may be able to fix it with Granville (not the Open All Hours variety) available from Halfords or any decent automotive bits 'n' bobs supplier.
**EDIT** Linky fingys added...
Granville:
http://www.halfords.com/motoring/garage-eq...ter-repair
Issue in more detail:
http://www.defender2.net/forum/topic8507.h...ow+element
http://www.defender2.net/forum/topic16715....ow+element
http://www.defender2.net/forum/topic2260.h...ar+element
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #379357 16th Dec 2014 8:43am
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Post #379358 16th Dec 2014 8:51am
CatherineF
Ahhhh,
I think this is going to have to be referred back to the dealer as the car has had privacy film applied, although I'm guessing that has just gone around the rear brake light housing.
Post #379361 16th Dec 2014 8:56am
K9F
This is the latter newer glass that has the element rerouted.
I too had a window tint and as a result couldn't get mine swapped out under warranty for the same issue. Also it may be that the tint was fitted after the issue was already there in which case the tint may need to come off. The window above was from a For Sale thread. If you need one they can be got from anyone that has or is going to have Landyglass/VSG or whatever it is called this week. May be worth giving David or Claire a ring if you need one? I subsequently replaced all my rear windows eventually so got rid of the issue. Good luck.
Post #379363 16th Dec 2014 9:00am
CatherineF
Is it likely that the brake light is suffering from the same issue?
Post #379369 16th Dec 2014 9:15am
K9F
Yes 'shared earth'.... first link after 'Granville' look at Dgardel's photo in the associated thread, it will become clear. (The problem not the window.) Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #379372 16th Dec 2014 9:24am
CatherineF
Doh!
Missed that bit! Thank you.
Fingers crossed we can get it all sorted without new glass and film.
Post #379380 16th Dec 2014 9:46am
CatherineF
Took it down to The Pike Associates in Trowbridge and they have ordered a repair kit. Decided as it was under warranty to take it to someone who should know what they are doing.
So fingers crossed by the end of the week it will be working.
Post #379430 16th Dec 2014 3:13pm
dgardel
Italy
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #379546 16th Dec 2014 9:54pm
CatherineF
Frustrated to say the least. It went in this morning to a local specialist.
He's confused and needs is back in early January to chase down the issue. Supposedly there was power and when it was tested a 2nd time there was no power to a connector top right.
The only thing he has noticed is a little mark on the black surround of the brake light (see photo).
Of course sods law it's Christmas and they will be closed so it can't be looked at until 5th January. Does anyone know of a good Auto Electrician in Wiltshire?
Post #381266 23rd Dec 2014 11:37am
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
If you want to make a temporary repair and are close to a motor factors you can buy a tube of paint on repair solution that will fill in a small nicks in the filament. something like this http://www.amazon.co.uk/heated-rear-window...pair%20kit or herehttp://www.halfords.com/motoring/garag...ter-repair Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #381289 23rd Dec 2014 1:20pm
CatherineF
Well that's what the specialist had supposedly ordered in.
I'm not impressed as you can gather because it was booked in for an hour. I wasn't there this morning but as I understand it, it now needs to go back in to be chased back.
I've got another specialist who also said bring it in on the 29th and we will have a look and maybe get someone in.
So I'm thinking I'd probably just be better with someone electrical.
Post #381320 23rd Dec 2014 2:46pm
x-isle
My brake light track (also early Defender) has failed near the connector down in the bottom right of the window.
To fix, I've run a cable up the side of the window seal to the light fitting (which bypasses the track) until I get around to fitting a new window. The cable is neatly out of sight. Craig Rogers
2007 Puma 110 XS
2011 Evoque Coupe Dynamic Lux
www.craigrogers.photography
Post #381323 23rd Dec 2014 3:17pm
Phatcat
United Kingdom 2002 Defender 90 Td5 CSW Java Black
If you speak to Dave at VGS ( formerly landyglass ) he will supply you with a tinted heated screen with LED , high level light for a very reasonable price.
Never been a fan of stick on tints for these potential related issues. Thumbs Up
Post #381331 23rd Dec 2014 3:36pm
