Home > Technical > PUMA Gear box MT82 problems
Drover
Australia
Well after 75,000K's the box in my SVX has spat 6th gear. It appears to be a chipped tooth, none of the other 5 gears are affected.
Ive dropped the oil for a look and didnt find any metal filings on the magnetec drain plug or any silver in the oil. Actually the oil was clean and in good order, it was only changed 10,000k's ago.
So the questions are -
1/ Do I rebuild the PUMA box and if so Ive heard that there are difficulties in doing this ?
2/ Will the Ford Ranger 3.2L MT85 bolt in ? What if any modifaction would need to be done ?
Thanks in advnance
Post #381214 23rd Dec 2014 3:32am
martinfiattech
I`ve rebuilt a couple of mt 82`s in transits. It`s not the nicest box to work on.
you will need a good set of pullers, bearing race heater, hot air gun ect.
The ones iv`e worked on have been a bit tight to get the shafts in and out of the casting.
As for the 3.2 I believe it`s a five cylinder unit, I think the mt 85 is a BIGGER box due to the increased torque of said power unit, weather it will mate to the transfer box without adjustment is another matter. Excuse the spelling I`am better with spanners and wires.
Post #381441 23rd Dec 2014 10:15pm
Drover
Australia
Hi Martin,
Thanks for your reply.
Do you or any others know if the bell housing bolts/clutch ect of the 3.2 match the the 2.4 ?
Additionally, was the out put shaft of the PUMA MT82 changed to suit LR transfer case or the TC changed to suit the MT82 ?
Thanks in advance for any info.
Post #390087 19th Jan 2015 8:28am
I believe that the bellhousing is the same, but there are others here who'll know for sure.
There is an (infamous) adaptor shaft fixed to the standard Ford output shaft, and a bespoke extension housing which physically attaches the standard Ford box to a standard LR transfer box.
Post #390151 19th Jan 2015 12:07pm
Drover
Australia
So if I have my original PUMA box as a doner, will I need this adaptor or between the two boxes will I be right ?
Post #390353 19th Jan 2015 9:27pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
The bolt pattern does match yes but the only difference is 2 bigger bearings I spat the 3.2 gearbox out behind my 3.2
And now have defender gears in it and tbh I think there stronger ?
3.2 gearboxes are like hens teeth I stick another std 2.4 box back in in my opinion
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #390368 19th Jan 2015 9:47pm
Drover
Australia
Hey Steve,
Here in Aus the 3.2 box (Ford Ranger) are readily available.
What was required to match up the transfer case. Being that I have the busted PUMA box as a parts donner, will I have all the available bits I need ?
Will the prop shafts length need to be modified ?
Appreciate you advice.
Post #390477 20th Jan 2015 10:14am
big steve
You will have all the bits all you need to do is swap the back end over with a few other mods
But as I said I have ripped 3 gears apart in the 3.2 box and replaced with them with te defender parts and it's had been fine since and that's got 240hp running through it ? 2015 2.2 tdci hardtop xs
Post #390499 20th Jan 2015 12:00pm
Drover
Australia
Thanks Steve,
Realy unsure what to do.
I've blown 6th after just 75,000k's.
A replacement PUMA box just seem like more if the same.
Post #390506 20th Jan 2015 12:31pm
