Home > Puma (Tdci) > Anyone seen the belt cutting into the air box
Bionicmunky
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Santorini Black
Just found this Sad
Any advice?
Thanks
John
Post #380929 22nd Dec 2014 11:23am
Bionicmunky
Post #380930 22nd Dec 2014 11:24am
munch90
for it to move that far , guessing engine mount problem ?
Post #380935 22nd Dec 2014 11:40am
Bionicmunky
Seems my airbox mounts have sheared Sad
Post #380958 22nd Dec 2014 1:02pm
dorsetsmith
Air box mounts have sheared look on the bright side easier fix engine mount Whistle
PJQ500030 x2
PyA10008L x2
PHU500060 x1
or PHB500340 kit
Post #380963 22nd Dec 2014 1:46pm
munch90
the pins that go through the rubber washers are moulded part of the airbox base
maybe the washers have broke , if not maybe someone has broken the airbox like someone had when the modded hose was fitted on the 2.2
the airbox can be a bit of a pig to get out , do a search for broken airbox
Post #380986 22nd Dec 2014 2:46pm
Bionicmunky
The dealer is going to sort under warranty, it had the hose service bulletin done when she was in a few weeks ago.........
Post #380992 22nd Dec 2014 3:10pm
tuesdayfox
2013 Defender 110 Puma 2.2 SW Zambezi Silver
I use a couple cable tie to secure the airbox (sadly).....
Post #381202 22nd Dec 2014 11:05pm
fatman
Greece 2007 Defender 110 Puma 2.4 USW Keswick Green
The way i look at it,somebody fitted the belt the wrong way,the ribbed section sound NOT be spining on that side of the pulley,the smooth side should..
Post #381588 24th Dec 2014 2:03pm
munch90
well spotted, yes is on wrong
also will be taking some of the belt off the alternator wrap round amount
Post #381590 24th Dec 2014 2:12pm
