Home > Puma (Tdci) > Anyone seen the belt cutting into the air box |
Bionicmunky Member Since: 15 Oct 2013 Location: High Wycombe - Buckinghamshire Posts: 108 |
Click image to enlarge |
22nd Dec 2014 12:24pm |
for it to move that far , guessing engine mount problem ?
22nd Dec 2014 12:40pm |
Seems my airbox mounts have sheared
22nd Dec 2014 2:02pm |
Air box mounts have sheared look on the bright side easier fix engine mount
PJQ500030 x2 PyA10008L x2 PHU500060 x1 or PHB500340 kit |
22nd Dec 2014 2:46pm |
the pins that go through the rubber washers are moulded part of the airbox base
maybe the washers have broke , if not maybe someone has broken the airbox like someone had when the modded hose was fitted on the 2.2 the airbox can be a bit of a pig to get out , do a search for broken airbox |
22nd Dec 2014 3:46pm |
The dealer is going to sort under warranty, it had the hose service bulletin done when she was in a few weeks ago.........
22nd Dec 2014 4:10pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
I use a couple cable tie to secure the airbox (sadly).....
23rd Dec 2014 12:05am |
fatman Member Since: 14 Jan 2014 Location: Athens-Greece Posts: 126 |
The way i look at it,somebody fitted the belt the wrong way,the ribbed section sound NOT be spining on that side of the pulley,the smooth side should..
24th Dec 2014 3:03pm |
well spotted, yes is on wrong
also will be taking some of the belt off the alternator wrap round amount |
24th Dec 2014 3:12pm |
