Home > Wheels & Tyres > ZU's / Mach 5's / Terrafirma's
Page 2 of 4 <1234>
Grockle
discocuzzy wrote:
I best get some 2nd wheels as well then Big Cry Big Cry Big Cry these wont last 2 minutes in salt
thats the problem with diamond turned wheels poor adhesion of the clear laquer on the polished alloy 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #37912 11th Aug 2010 3:10pm
Mad Cow
England 2007 Defender 90 Puma 2.4 HT Zermatt Silver
If price is an issue, how about modulars and 255/85 x 16 Cooper STs
These are in gunmetal rather than black, £495 for 4 from Silverline last month, although I see they have gone up to £545 now
And YES I know I should have gone for the writing on the inside but I forgot to ask!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  MAD COW
2007 90 Hard Top - 2009 BMW F800GS - 2002 CCM 604E Dual Sport
Project90
Post #37984 12th Aug 2010 4:58pm
K9F
Good price when you consider Mach 5s and boots will cost you two and a half times that! Zu's not much cheaper either!
Depends on your bling factor and budget! Whistle
PS Writing's ok on the outside in my book! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #37985 12th Aug 2010 5:05pm
BigRuss
I'm after either the ZU or the mach 5's because I like the look of the wheels.
I'm not to worried about the cost because it would annoy me to much if they didn't give the look I'm after and I wanna get the right size tyre that will fit and be suitable for my needs. I know a lot of people on here have started going for the 285's or the 255's for the larger diameter but I do like the look of a landy with massive tyres but don't want to have to modify much to fit the tyres.
Madcow
Are you sitting on standard shocks or +2"?
Post #37987 12th Aug 2010 6:17pm
Chunk
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I'm saving up for a set of Blindo's, they look the dogs danglies Bow down
Post #37992 12th Aug 2010 8:00pm
BigRuss
I looked at the Blindo's but I don't like how the centres come so far out so they'll be prone to damage where as the rest all have the metal work safely tucked away.
Post #37995 12th Aug 2010 8:25pm
Mad Cow
BigRuss wrote:
Madcow
All bog standard, only clearance issue is the rear tyres just clip the outside crners of the eyebrows but as they are flexible it doesn't seem to make any difference (paint is still intact). If they were black, I would have just trimmed them but it wouldn't look so pretty with the silver paint.
Steering is fine due to the extra 20mm of offset you get with the modulars.
Did a 2" lift on a Disco once and never liked the way it handled afterwards.
I must say I liked the idea of Zus but I paid £124.75 per wheel/tyre, with Zus at £125 each for just the wheel, It was an easy decision to make... and I like the look of modulars too, this is third vehicle that I've fitted them to MAD COW
Project90
Post #38002 12th Aug 2010 9:22pm
K9F
Fekete's on 10 X 15 Modulars with a 2" lift.....
You could theoretically go down a similar route as myself to get a new set of Mach 5s....
As money is no object....Just had a look at Devon 4 X 4....
They have three 10 X 16 Mach 5s in black and two in plain silver....You could get the silver one(s) recoated black by them and have a complete set the same.....Still reckon you'll be very hard pushed to find a new set available anywhere else! They may not be the size you wish (but they are the same width as mine and Feketes wheels if you want go see in the galleries)....Beggars can't be choosers and as mentioned before Mach 5s are like rocking horse poo....rare availability....Just an idea!!!! By remaining on 16" wheels there would be no calculations involved if you wished to retain original rolling radius but I personally wouldn't go bigger than 265 due to the offset of the Mach 5s and 'arch accommodation' and articulation (all factors to consider). A decent tyre supplier could always fit one first to see how it would suit for you dependant on their stock!
I have a 90XS with 'Heavy duty' standard suspension my wheels do not foul at all.
Post #38012 13th Aug 2010 8:20am
bob neville
16" ZU's fitted with 265*75*16 BFG AT's.
No mods as the extra 11mm offset counteracts the extra tyre width and the tyres do not touch on full lock.
Post #38022 13th Aug 2010 12:12pm
Cibit
One of my terrafirma wheels has a huge gash where a rock impacted. Seems to be quite soft alloy. ZU's may be more robust but cannot comment. I do like the TF wheels though Thumbs Up 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #38159 15th Aug 2010 11:56am
K9F
Pizza Base!
Personally I prefer 'deep dish' with a 'stuffed crust' rather than 'thin and crispy' or Ice Cream Van stop me and buy one - like!
Rolling with laughter
On appearance ZUs and Mach 5s are very similar or rather they can be dependant on width....
Post #38164 15th Aug 2010 2:52pm
BigRuss
Now the ZU and Mach 5's having the spokes tucked up ou of harms way is what I like unline the blindo's and terrafirma's
Post #38165 15th Aug 2010 3:29pm
K9F
Below is another picture of a ZU, the spokes are obviously not that far tucked away from harms way....in comparison to the Mach 5s above I'd say....
Whatever you decide black wheels are gonna look cool on your truck for sure! Thumbs Up
Post #38169 15th Aug 2010 4:37pm
BigRuss
I agree with you on both counts K9F
Post #38176 15th Aug 2010 5:59pm
TF's the way to go Mr. Green
until salt goes on the roads Big Cry
Post #38184 15th Aug 2010 6:37pm
Page 2 of 4 <1234>
