Home > Puma (Tdci) > Rattling when accelerating
Josh K
United Kingdom 2007 Defender 90 Puma 2.4 HT Orkney Grey
I've done a search on the forum but nothing seems to quite match what I'm looking for.
My 90 seems to be suffering from an issue where I get quite a violent sounding rattle when the engine is under load. It only seems to be noticeable when accelerating between 40 and 60mph or when going up inclines. It's normally only present when in 5th or 6th. It's definitely nothing inside the cab but I can't seem to tell whether it's front or rear of the vehicle. It stops as soon as I take my foot of the accelerator.
Any thoughts?
Josh 2007 (57) Defender 90 (Sold)
Looking for another to replace it.
The road less travelled.... is a muddy one!
Post #375276 30th Nov 2014 5:46pm
Post #375283 30th Nov 2014 6:02pm
charlesteton
I had similar, turned out to be heat shield loose. Smile
Post #375287 30th Nov 2014 6:11pm
Josh K
It's definitely not the gearstick rattle as I've previously sorted that and it's much louder than that. It's also not the turbo heat shield as I've checked that but need to get underneath but I'm hoping to come up with a list of areas to check from the ever helpful members of this forum. 2007 (57) Defender 90 (Sold)
Post #375292 30th Nov 2014 6:17pm
May be prop balancing.
Post #375310 30th Nov 2014 7:00pm
I have a somewhat similar rattle which I thought might be heatshield, but then I found by means of "the elbow test" whilst lying underneath that it is the bracket holding the front offside mudflap to the chassis.
Post #375399 30th Nov 2014 10:14pm
LesDef
Hi Gentlemen,
Just found the Steering Damper dust cover loose, rattling and rubbing on the inner housing. Hope to have it replaced under Warrantee.
Regards Lesdef
Post #375422 1st Dec 2014 3:53am
Josh K
I've potentially found the problem. Topping up various fluids just now and I found that the red eye at the back of the engine was loose. I've tightened the 2 bolts up so I'll see later whether that has cured the rattling.
Thanks everyone for your help. 2007 (57) Defender 90 (Sold)
Post #376048 3rd Dec 2014 12:14pm
Josh K
Right a couple days have passed and the loose lifting eye in the engine bay was not the issue. I've booked it in for a service next Friday so I'm asking them to remove the prop and check the UJ's. Hopefully they'll sort the oil leak from the oil filter as well. 2007 (57) Defender 90 (Sold)
Post #376659 5th Dec 2014 5:13pm
Josh K
Right so the truck was serviced and a rather long list of faults were rectified including corroded brake lines, new front pads and discs, N/S front CV joint amongst other things. They looked at the UJs and greased them all but found no excess wear or play. On the road test the wind speed was gusting upto 65mph so was impossible to hear the rattling. They're going to have another look but I'm hoping you guys might be able to suggest possible culprits.
So far ruled out:
Gearstick rattle (already been fixed)
Heat Shields
UJ's
Loose Brake pads
And the main symptons are:
Rattling under acceleration (more pronounced going uphill)
Scanguage reports water temperature increases to 96-98 degrees 2007 (57) Defender 90 (Sold)
Post #383419 30th Dec 2014 5:33pm
landy andy
I assume it's not a rattle from the engine?
Post #383481 30th Dec 2014 8:45pm
Lou Sparts
United Kingdom 2005 Defender 90 Td5 XS CSW Zambezi Silver
Is it like a "pinking" noise you would get on a petrol engine ? 2005 Td5 90 XS
Steve
Post #383491 30th Dec 2014 9:09pm
K9F
Water temperature is fine. Could it be either the upper or lower heatshield on your catalytic convertor? My turbo one also rattled but this was due to a tear in it, difficult to see and determine and not due to the bolts being loose. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #383502 30th Dec 2014 9:45pm
landy andy
I've also had rattly heat shield on crankcase sensor (on bell housing behind cat) and now I've got rattling from transfer box mount heat shield (beneath drivers feet)
Andy
Post #383534 30th Dec 2014 11:48pm
Mongolia
France
I had a similar sound. It was the front low attachment of the damper which was unclamped and the damper shaft was rubbing on the fixing hole which was no longer round. Once tightened, no noise
Post #384430 3rd Jan 2015 10:17am
