Home > In Car Electronics > Dodgy aux-in jack on LR head unit? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20480 |
Poor connection to the jack most likely, doubt repair is viable.
Used Defender HU's commonlylp sell for relatively low prices. |
28th Nov 2014 9:55pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17470 |
One thing to check is that the diameter of the body of the plug isn't too big to allow proper engagement. The socket is recessed slightly in a circular recess and I used to find (before I changed the HU) that most plugs wouldn't go in far enough for a reliable connection.The result was crackling and one channel dropping out.
When I eventually found a lead with an unusually small plug body all was OK. Failing that it could be dirt in your socket, or a dry joint between the HU connector and pcb, neither of which can really be dealt with easily. |
28th Nov 2014 10:46pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3646 |
as blackwolf said you need a small diameter plug body to fit properly DEFENDER 90 TDCI XS,
29th Nov 2014 7:28am |
jerseyman Member Since: 21 Jul 2009 Location: Jersey Posts: 279 |
I had the same problem on my 2012 2.4. Tried multiple leads and all were the same. I should have persevered with getting it fixed under warranty.
29th Nov 2014 9:24am |
lohr500 Member Since: 14 Sep 2014 Location: Skipton Posts: 1319 |
If it isn't a mechanical issue due to the size of the plug, I would try a little squirt of electronics switch cleaner or a blast from one of those aerosol air dusters down the hole before writing it off. As blackwolf says it could be dirt or dust that has got in there.
29th Nov 2014 5:48pm |
