Home > In Car Electronics > Dodgy aux-in jack on LR head unit?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi all,
Anyone else ever get a dodgy aux-in jack on their LR head unit? Mine initially was OK, but the audio one side started to sputter in and out, and eventually gave up the ghost.
When it is on CD or radio, stereo functions fine. I've tried different cables from the iPhone, different phones/iPods etc - nada.
Back when the 110 was still in warranty I complained to LR about it, but they squirmed out of it somehow, too much of an effort to address that when there were more important things to cover.
I was considering popping out the radio and seeing if it is a bad soldering joint or something... Rolling Eyes
Post #374954 28th Nov 2014 9:29pm
Poor connection to the jack most likely, doubt repair is viable.
Used Defender HU's commonlylp sell for relatively low prices.
Post #374961 28th Nov 2014 9:55pm
One thing to check is that the diameter of the body of the plug isn't too big to allow proper engagement. The socket is recessed slightly in a circular recess and I used to find (before I changed the HU) that most plugs wouldn't go in far enough for a reliable connection.The result was crackling and one channel dropping out.
When I eventually found a lead with an unusually small plug body all was OK.
Failing that it could be dirt in your socket, or a dry joint between the HU connector and pcb, neither of which can really be dealt with easily.
Post #374979 28th Nov 2014 10:46pm
LR90XS2011
as blackwolf said you need a small diameter plug body to fit properly DEFENDER 90 TDCI XS,
Post #375003 29th Nov 2014 7:28am
jerseyman
I had the same problem on my 2012 2.4. Tried multiple leads and all were the same. I should have persevered with getting it fixed under warranty.
Post #375010 29th Nov 2014 9:24am
lohr500
If it isn't a mechanical issue due to the size of the plug, I would try a little squirt of electronics switch cleaner or a blast from one of those aerosol air dusters down the hole before writing it off. As blackwolf says it could be dirt or dust that has got in there.
Post #375059 29th Nov 2014 5:48pm
