Home > Puma (Tdci) > 2009 110 starting / running issues... |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
My money would be on the 10AS. Water corrodes the terminals, causes many issues. Unplug it, clean/wipe off the connectors with WD40 and see if it helps ....... Guns and Landrovers .... anything else is irrelevant.
26th Nov 2014 9:54pm |
Fuel filter ?
27th Nov 2014 6:58am |
Landy RS Member Since: 11 Nov 2014 Location: Somerset Posts: 7 |
Thanks Dave-H and bpman!
It's not rained today and there's no problem with starting or running. There is plenty of water leaking in behind the dash so I obviously need to sort that and waterproof the 10AS unit... Is there any issue with unplugging the unit and then reconnecting it? |
27th Nov 2014 9:09pm |
Not normally, Just leave the ignition switch alone [and OFF] just in case Guns and Landrovers .... anything else is irrelevant.
27th Nov 2014 9:27pm |
