Home > Technical > Worth rebuilding the starter motor ? |
There's a kit on ebay which is easy to fit and reasonably cheap. Try a search for defender starter motor repair kit.
20th Nov 2014 10:54pm |
If you get hold of the kit to repair the solonoid it will become clear. The last time I did mine it took longer to get the starter off than swopping over the contacts. IIRC you could do it whilst still fixed to the motor, you can get into quite a comfortable position sat under there.
20th Nov 2014 11:15pm |
Paulpen Member Since: 01 Mar 2014 Location: Somerset Posts: 20 |
I dont thin its the contacts causing this issue though - its more the loose 12v stud that shouldnt move and dont know if thats fixable !
20th Nov 2014 11:21pm |
The study is one of the contacts inside, it is shaped inside to match up with the contact on the plunger. A quick way to see is to take off the cover off the solenoid but disconnect the battery first.
21st Nov 2014 7:29am |
I have done lots of the same style of starter as there fitted to lots of rovers etc , and always just replaced the contacts and never had a problem with one even had people say its the best its ever been at starting
with the first few I done we had to make the contacts out of copper sheet as you could buy them on there own back then there are a few different style of contact , I think they all fit but some are a bit more heavy duty (wider contact area ) |
21st Nov 2014 8:11am |
wizz80 Member Since: 06 Dec 2012 Location: north devon Posts: 38 |
just do the contacts and plunger loads of kits available on ebay etc i have done loads and never any trouble i dont even remove the starter any more. Wizz
26th Nov 2014 12:27pm |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
I had the same problem. I bought the kit off ebay. The hardest part was undoing the 3 bolts that hold the starter motor on.
Starts first time now and will hopefully do so for the next 11 years or so |
26th Nov 2014 2:16pm |
Ta for all the advice
After running through it all with him speed was of the essence as he was losing money daily due to it not starting at all now. He managed to collect a new starter from Devon4x4 so thats been fitted and we will rebuild the old one and keep as a spare when we have some spare time |
26th Nov 2014 5:47pm |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 |
Good stuff. FYI I find the 15mm nut on the top of the starter mounting far easier to get at lying over the top of the engine with a spanner. Might be of use to someone. Far easier than trying to fight with it from underneath with a menagerie of sockets and extensions.......
26th Nov 2014 6:45pm |
