Home > Maintenance & Modifications > how to fit a roof lining
Shutts
United Kingdom 1995 Defender 90 300 Tdi SW Arles Blue
Guys
Just managed to lay my hands on a new roof lining for a 90. Does anyone have a guide on how to fit it, and what additional items I would need to fit it to a hard top.
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
()_)' '()_)-----()_)
2005 D3 SE
1998 Disco 300tdi - slow play thing
1995 Defender 300tdi - Winching play thing
Aprilia RSV 1000 - fast play thing
Honda CR250 - noisy play thing
Essex Land Rover Club member
Andy's Landy's - http://www.andys-landys.blogspot.com
Suspension checking workbook - http://www.disco3.co.uk/gallery/albums/use...k_v002.zip
Post #372342 17th Nov 2014 11:21pm
Knot-yet
I recently fitted the missing rear section of headlining to my base spec hard top.
And found the LRM defender 110 headlining articles on following webpage useful as a general guide before tackling the job.
http://www.lasalle-trim.co.uk/media
Hope this helps
Post #372857 19th Nov 2014 9:25pm
Shutts
Knot-yet
Many thanks for the links, they will be very useful when fitting the new linings. Do you know if I need any more brackets, also the number of fir trees clips required.
Shutts |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #372886 19th Nov 2014 10:36pm
TD5 SMUT
United Kingdom 2005 Defender 110 Td5 XS DCPU Java Black
Hi
about 10 fir tree clips will do the job, first link up a rear light from the front one (off flebay) that holds it in the right place to put the rest of the fixings in
its fairly easy just makes your shoulders ache!!!
Post #372908 19th Nov 2014 11:55pm
TD5 SMUT
Just done the same to mine but a dc is a bit of a pig!!!
Post #372910 19th Nov 2014 11:58pm
smb
A great idea from someone on here(sorry, can't remember who) is to use a camera tripod to hold the lining in position whilst you do the final fixings. Thumbs Up
Post #372912 20th Nov 2014 12:04am
TD5 SMUT
Fair play, thats a great idea.
Post #372916 20th Nov 2014 12:21am
MarkyMark
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I really like the dark roof lining Thumbs Up and now I must resist adding it to my growing future upgrade
Post #372926 20th Nov 2014 2:15am
TD5 SMUT
Yes i am really impressed, i have sound proofed the whole cab too i will post a load more images later,
i know of the same liner for a 90 at the right money!!
pm me
Post #372960 20th Nov 2014 10:42am
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Hope this helps
Knot-yet,
When you fitted the rear lining to your hard top what did you do about fitting the rear piece that goes over the door? On a SW there are metal brackets spot welded to the roof to push the fir tree clips into, obviously these are omitted on the HT roof.
At the moment the rear over-door piece on mine is just held in by the two grab handles and I pushed the fir trees into the section just to hide the holes. Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #372966 20th Nov 2014 11:27am
TD5 SMUT
Dont know sorry!! maybe rivet a piece in?
Post #373134 20th Nov 2014 9:36pm
Knot-yet
I'm still scratching my head over that one. The best I can come up with so far is to make up the necessary bracket from a piece of aluminium and bond it with something like sikaflex adhesive.
At the moment the bit over the door is not fitted.
Post #373720 23rd Nov 2014 3:20pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
When i did this I made 2 brackets up and riveted them in place. Also I used Sikkaflex to set the sockets for the 2 grab handles in place.
Post #373728 23rd Nov 2014 4:57pm
Shutts
Guys
After about a year I managed to get the time to cut in the alpine roof lights and fit the roof . Interestingly only 2 out of 6 holes lined up so I will need to drill the other holes. However, one thing I found is that the fir trees don't seem long enough to hold.
Can anyone tell me if there are longer ones to go through both roof liners?
Andy |____000_
[l_|__\___\,___
l--___--_[O==O]
2005 D3 SE
Post #527145 26th Apr 2016 9:26pm
