Home > Puma (Tdci) > Midium pich whining noice. Feature or fault?
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Turned of the radio, which is usually on, and now U hear a wining middle pitch noice which goes away when clutch is pushed in and rolling. Is this an issue wayting to become a problem or just a Defender feature?
Have driven it like that for many thousend miles probably...
2.4 TDCi
Post #371338 12th Nov 2014 9:47pm
LR90XS2011
if when stationary with engine running at idle and clutch pedal released its noisy, but with clutch pedal pressed its quiet its most likely the clutch plate springs, see post re my similar noise
http://www.defender2.net/forum/topic31167.html DEFENDER 90 TDCI XS,
Post #371347 12th Nov 2014 10:11pm
zone30
As I complained about drivetrain play before my waranty ended, I hope they will solve it under warranty.
To be continued...
Post #371437 13th Nov 2014 3:05pm
LR90XS2011
good luck DEFENDER 90 TDCI XS,
Post #371488 13th Nov 2014 7:56pm
Alicat
Sounds a bit like the issue I had recently, mine was more of a whopping noise. Could be heard at low speeds when rolling in gear, went when the clutch was pressed down.
It was diagnosed as excessive wear in the splined section that connects the main shaft to the transfer box, and interestingly, since it was fixed there is less backlash in the transmission.
Good luck
Tony
Post #371541 13th Nov 2014 11:14pm
zone30
I think it is something else as the whining is rev based, no matter if I'm standing still or driving, in or out of gear, clutch in or out. What can it be?
Post #371544 13th Nov 2014 11:58pm
Alicat
Sounds more clutch related then. The noise I had was road speed dependant.
Tony
Post #371550 14th Nov 2014 12:20am
LR90XS2011
that being the case it must be something that rotates all the time with the engine. have you had a listen under the bonnet to see if its coming from the front or rear of the engine, left or right side. A long screwdriver pressed to various metal parts of the engine and then placed by an ear will often locate the source of rumbles and knocks DEFENDER 90 TDCI XS,
Post #371562 14th Nov 2014 6:39am
munch90
whining is normally bearing noise , poss alternator , water pump , belt idler , belt adjuster , vicsous fan , belt its self , steering pump
Post #371591 14th Nov 2014 10:29am
zone30
Sounds like the whining when you drive in reverse.
Post #371698 14th Nov 2014 10:35pm
munch90
The whining in reverse is because the gears used for reverse in most boxes are straight cut and not helical cut , sorry I know this doesnt help ,
but do you get the whining noise then stationery and foot on clutch
Post #371701 14th Nov 2014 10:46pm
zone30
Yes. If the engine revs the noise follows, regardless if I'm moving or not.
Sounds like this:
Post #374200 25th Nov 2014 8:33pm
zone30
If anyone has any feedback on this, I would be very grateful.
Post #374335 26th Nov 2014 6:27pm
zone30
Up
Post #374538 27th Nov 2014 11:04am
zone30
It's a pully or what's it called?
A wheel that is driven by a rubber belt driven by the engine.
Post #374716 27th Nov 2014 10:52pm
