Home > Technical > Which gasket sealant for diffs? |
something like this eBay item number:
eBay Item No. 261463521938 if your going to use sealer on paper gaskets , be careful with how much you use as it will make gasket slide and split and push out round the joint you only need a very small amount , people always use too much and it just pushes out and knackers the gasket and if its got a big lump on the outside then there will be on the inside as well and just makes the job look a mess and bodge up |
4th Nov 2014 6:55am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5739 |
I always just use silicon. Have done for years without any issue, they aren't under any pressure and it makes it a simple job.
Andy |
4th Nov 2014 7:15am |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 574 |
Agree with Andy,silicone is fine.....& cheap.
4th Nov 2014 7:20am |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 |
+1 for silicone, used it for years on the Bowler! 2014 110 2.2TDCi XS Station wagon
1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
4th Nov 2014 8:22am |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 |
Personally speaking I would use Hylomar Hylosil.
http://www.ebay.co.uk/itm/Hylomar-Hylosil-...3f3c992a49 |
4th Nov 2014 9:26am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17466 |
Hylosil is what LR use on the production line. Gets my vote.
Diffs (and sumps) now are sealed just with Hylosil and no paper gasket is used. |
4th Nov 2014 10:23am |
