Home > In Car Electronics > Fitted! Double DIN Parrot Asteroid Smart. + now DAB |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
does the tom tom apk have speed cameras?
31st Oct 2014 10:14am |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2754 |
I *think* so, but you may have to subscribe or set it up in some way.
It does on iPhone, and I've seen on my smart that you can definitely pay for traffic etc. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
31st Oct 2014 11:30am |
Fitted my Dension DAB addon today, with a powered aerial/splitter thingy from DabOnWheels.
Very happy with the results. It plugs into the USB on the Smart and gives each station as a .mp3 file as if you were browsing a USB full of music files, very clever. Only slight annoyance is a 15-20sec buffer at the start of each station when you switch to it. Signal through the standard aerial (now amplified) is very good. I'd say nearly as good as our Range Rover but not done much testing yet. Perfect reception on a short journey I made before. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
2nd Jan 2015 1:32am |
Paddie42 Member Since: 24 Apr 2014 Location: Hamphire Posts: 230 |
There seem to be a few different powered DAB splitters that allow you to use your existing aerial.
Found this thread that might help; http://www.defender2.net/forum/topic31762.html I used one from Autoleads, bought from Amazon. From memory it cost about Ł30. The reception is great for DAB, better than a factory fitted unit I had in my Ford Galaxy. |
2nd Jan 2015 9:15am |
yep, you got it.
This is the product that DAB on Wheels recommended- http://www.dabonwheels.co.uk/High_performa...ctive.html but its available on eBay for less than a 1/3 of the price, the exact same! Not sure what happened but id still recommend DAB on Wheels, theyre good for advice and some of their other products are better priced. I bought this exact item, arrived very quickly and works like a dream... http://www.ebay.co.uk/itm/Kinetic-DAA-7001...19e9b28ba2 Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
2nd Jan 2015 12:06pm |
this is the Dension DAB+U that i bought, for anyone interested:
http://www.amazon.co.uk/dp/B00HW1W37S/ref=...71_TE_item Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
2nd Jan 2015 12:07pm |
Northernremedy Member Since: 18 Aug 2014 Location: Yorkshire Posts: 122 |
Cheers! Looks a lot easier than routing via alpine window
2nd Jan 2015 12:35pm |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 |
Might be me, but seems like a huge gap underneath the vents?
2nd Jan 2015 1:08pm |
yes there is!
the double din facia doesn't come with the clock/vents bit so you have to cut that bit off the old facia. You then need to glue it to the new facia but I've never got round to glueing it in place to be honest! i think id left it sticking out a bit when i took the picture too, its better now. Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
2nd Jan 2015 1:54pm |
Thanks, will think it over again I guess.
Maybe I should just upgrade to a single din and skip the reverse camera / screen part... |
2nd Jan 2015 10:46pm |
It's really not a difficult task, just one I never got around to doing yet... Cheers, David
2nd Jan 2015 11:15pm |
Arsath Member Since: 20 May 2015 Location: Sri Lanka Posts: 133 |
has anyone else tried fixing this volume control to Parrot
You can buy the control here http://store.fusioncontrolcentre.com/index...duct_id=61 I am thinking it will fit neatly in the circular space in the extended fascia.. @Davidwhittaker Any wiring adapters that I should buy to connect Parrot if I am replacing the stock Defender Audio? |
20th May 2015 9:33am |
I bought one a while ago and it just plain didn't work. Don't know if I was doing something wrong or if it was broken, but I gave up anyway. Didn't find anywhere useful to put it and I got used to not having a knob, it's fine for me. Cheers, David
21st May 2015 8:13am |
Ahmed Member Since: 16 Mar 2015 Location: Bahrain Posts: 13 |
Hi Arsath,
Yes fitted and works great, here are some pics that i took during the install. Used small screws to secure a square teflon piece from the front under the nob, and 4 small screws again to secure the controller to the teflon. I don't have a dipper switch on my car, thats why i used that empty space Click image to enlarge Click image to enlarge |
29th May 2015 6:46pm |
