Home > In Car Electronics > Fitted! Double DIN Parrot Asteroid Smart. + now DAB
Page 3 of 7 <1234567>
Very well done anyway, does indeed look OE. Thumbs Up KEEP CALM AND Drill ON
🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª
Post #316635 17th Mar 2014 4:30pm
Cheshire110
Yeah maybe a xtech/lxv style corris grey surround would look good... Hmm
Don't give me ideas! Cheers, David
Post #316833 17th Mar 2014 10:42pm
Too late, Killer could knock you one up. Whistle
Rolling with laughter KEEP CALM AND Drill ON
Post #316834 17th Mar 2014 10:46pm
dgardel
Italy
Outback Engineering??? Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #316854 18th Mar 2014 4:58am
RouseyD
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Corris Grey
Hi David
I agree with the other comments - it looks fantastic.
I may have missed it, but have you got a reversing camera hooked in yet / do you plan to?
Now you've lived with it a while, how have you found the Parrot system?
I have been looking at a couple of single din solutions where the screen pops up for sat-nav and reversing camera duties, but didn't want to obscure hazard light switch and this looks far more elegant.
Cheers,
Dave
Post #317766 21st Mar 2014 10:54am
On a single DIN you can adjust the screen out wards so you can still access the switch. KEEP CALM AND Drill ON
Post #317770 21st Mar 2014 11:08am
RouseyD
custom90steve - thanks - when I was looking, the models I'd come across online (not in the flesh) seemed like they would obscure the switches, or at least the screen would need adjusting at the time of accessing the switches.
Now I've seen David's installation, my personal preference is very much toward the fully integrated look. The ability to use TomTom software as well, is (personally) appealing.
I'm keen to hear especially if there are any niggles or things where the Parrot doesn't behave as one might want (e.g. responsiveness).
Cheers, Dave
Post #317774 21st Mar 2014 11:31am
Cheshire110
RouseyD wrote:
Hi David
Cheers,
Dave
Thanks, as I'm sure you can tell I'm very pleased. Wasn't expecting anything like as good a final product as I've ended up with.
No reversing camera yet, but it is very much on the to-do list, maybe around easter ill get one sorted but I'm not home much (at uni in London) at the moment so been no real rush to get it sorted. I think ill probably get one something like this, maybe fit it onto a bracket somehow attached to the number plate light or maybe high up near the rear window washer nozzle, will have to think about it.
As for the parrot, ive had a handsfree kit and the single din asteroid off them before so i knew what to expect. This system, however, is particularly good. The bluetooth (audio and handsfree) are perfect, and the voice dialling superb (as with all parrot kits). The fact that i can also run onboard diagnostics, satnav, reversing camera etc ontop of the standard functions too is just brilliant. It also has Wifi, 4x USB, line in, video in and out (can support 2 rear screens too!) so it has all the bases covered.
Ease-of-use-wise, Its just the right mixture of function and simplicity. Its more similar to an iPhone than android in many ways, as the interface is a custom one which has been much simplified compared to standard android which can be a bit feature heavy and clunky in my opinion.
As you said, i didn't want a flimsy pop up screen which also blocks switches and vents , so this was my best option.
The only downside I have found is that volume is slightly difficult to do when you are using satnav or another app (not the app playing the music currently) and driving. When you just have the radio on or whatever you can use gestures to adjust volume etc, but when the satnav or OBD scanner etc is on the screen you have to use the volume soft key then slide a slider. Thats why I've purchased my USB volume know which i hope to set up soon.
Otherwise, its absolutely perfect and when it was in the dealers the other day the mechanic popped out to say to me that he'd had a fiddle with it and he thought it was the best head unit he'd ever seen in a defender, with respect to both the head unit itself and its fitting into the car.
The other thing to mention is that it costs only around £450 off ebay (maybe even less) new with warranty etc, so its a hell of a lot cheaper than any equivalent from Alpine/Pioneer/Sony etc (as much as £999-1200 or more!) and in my opinion i wouldn't swap it for anything else.
If anyone likes, i can help you get the TomTom app (latest version 1.3) with ALL EUROPEAN MAPS for android (will work on 99% of android phones, as well as the asteroid smart etc all for free Smile Compare that to the often £200+ extra 'satnav' add-on that most head unit manufacturers will charge you for such maps/navigation.
Its also worth mentioning that the Asteroid DOES come with a gps antenna included, and a navigation app called 'iGO Primo' on a few months trial, although i thought it was pretty poor. TomTom Europe is around £55-60 i think, but as I said i can help anyone get it for free very easily.
The expensive cost, really, is the £300 or so for the double din facia.
Any questions, fire away! Cheers, David
Post #317776 21st Mar 2014 11:57am
Cheshire110
It is incredibly responsive, i was very surprised since the asteroid single din was fairly average. Its really impressive.
Ill make a video of it in action and my setup in a week or so when i get back.. Cheers, David
Post #317780 21st Mar 2014 12:07pm
Egghead
My double DIN unit, which pops out on engine ignition and hides my switches Mad
The clearance behind the unit's screen can be adjusted in settings so that it sits fairly flush with the facia, or tilts a little, or stands out proud - so behind the screen is (just) accessible. The screen is reasonably sturdy and doesn't wobble too much except when the off road tracks I use are horrendous, then it's best to close the screen away. Reaching the switches behind though is not too good even with the screen at its maximum distance setting. It's a nightmare trying to give a quick set of thank you flashes with the hazards whilst zipping along the motorway! Rolling Eyes
I use that reversing camera you have indicated (or pretty similar) and i have it mounted above the rear screenwash jet. Works a treat (see pictures) except for a crack in the screen which slightly hampers vision when it has been raining and condensation fogs up the view! I enquired about a replacement lens cover but it looks like I'll have to replace the whole unit. You can compare prices of the unit with your own sources with this link.
Here are some pics of the camera mounted at the rear and the camera view I get on the dashboard screen...
As I have an OBDLink LX unit I am very keen to explore the Parrot Asteroid Smart - then I can solve the other issue I have with my current setup where during winter the heating vents blow straight onto the popout screen. Shocked
Post #318298 23rd Mar 2014 9:22am
Cheshire110
Yeah the heater/switches are the main reasons I didn't go for a single din pop up like you, that and also I wanted it to look as factory as possible.
I honestly can't recommend the parrot asteroid smart enough!
The torque app (obd diagnostics & gauges) is great, as is the tomtom as mentioned before Cheers, David
Post #318345 23rd Mar 2014 11:36am
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
I've got a double din facia ti install and am looking at the asteroid smart. does the sat nav have to use 3g all the time?
Post #318731 24th Mar 2014 5:17pm
Cheshire110
No, it comes with iGo installed on a trial (on an SD card) which I found pretty poor.
So I downloaded tomtom Europe - it can be purchased off the asteroid market on the device itself or on a computer then transferred via SD to the device - but I downloaded it online using a well known Swedish website and it works like a treat. All the maps are stored on the device- I've never even used 3G on the device.
It works like a dream Cheers, David
Post #318749 24th Mar 2014 6:03pm
The double DIN is the best option if you can afford it, but it is MUCH more expensive.
The cost is high not so much because of the actual HU but because the dash costs a lot. Rolling Eyes
Both have advantages and disadvantages. And both have grave security vulnerability which I will not quote online. Shocked
Only thing that annoys me with any system that after only about a year there will be a new model with different or better features.
For a very top of the range HU (with all the bells and whistles) and dash etc you could easily blow £1000 - £1800.
Also what ever system you have it needs a good interface that you can update through PC etc.
Is this one David actually removable or USB updated?
Most of Kenwood and other manufacturers are via USB.
I think iPad style if not an iPad in dash easily removable is the way to go.
It's pretty much hot everything then. KEEP CALM AND Drill ON
Post #318757 24th Mar 2014 6:24pm
Cheshire110
yeah i agree with you there, Steve. You see the satnav units in other cars and which were fitted a few years ago (ken wood, sony, pioneer etc etc) and they look very outdated, maps need a costly update disc or can't be updated and often don't support newer technologies etc
thats why i went for the Asteroid, as it can be updated via USB as you mention, but also it runs android apps and has all the basic technologies built in (Bluetooth, wifi, GPS, USB etc) so i can pretty much add whatever functionality I like in the future, as android is a brilliant platform (and thats from an iPhone/mac user!) which is well catered for in the development side. Also android supports lots of hardware which i may wish to add on in the future
Also the satnav being tom-tom means that there are regular updates etc released so i won't be stuck like dads land cruiser which doesn't know of the M6 toll!
I think its generally a more future proof unit, and also being only £425ish it isn't the biggest outlay to lose should a better alternative become available in the future. A comparable Sony/Kenwood/Alpine/pioneer unit would be over £1000 and much harder to keep up-to-date/install anything yourself Cheers, David
Post #318797 24th Mar 2014 7:52pm
