Home > Puma (Tdci) > Whooshing Noise from Transmission (Updated)
Alicat
Well over the last couple of weeks the Defender has developed a whooshing noise from the transmission at low speed. It is a rotating sound, a bit like the handbrake just making contact.
It has also developed a vibration when braking hard.
Anyway, went in for a service today, just been phoned, sounds serious, the warranty guy from Land Rover is inspecting the vehicle in the morning.
Any known problems?
Thanks
Tony
PS 2.4 with 16000 miles on the clock
Post #367807 28th Oct 2014 6:31pm
Pickles
Could it be something to do with traction control?
Pickles.
Post #367876 28th Oct 2014 11:05pm
Alicat
So the diagnosis is gearbox main shaft wear!
Now waiting for it to be repaired.
Tony
Post #368047 29th Oct 2014 5:20pm
Alicat
Just picking the Defender up. The problem is the splined connection between the main and transfer box. This was badly worn, but had not got to the point of failure.
Same problem that has been discussed on here before.
Tony
Post #368486 31st Oct 2014 4:13pm
LR90XS2011
glad you found it was it fixed under warranty? DEFENDER 90 TDCI XS,
Post #368577 31st Oct 2014 9:03pm
Alicat
Yes, fixed under warranty.
Post #368585 31st Oct 2014 9:23pm
Can you tell us what they actually did?
Post #368764 1st Nov 2014 5:03pm
Alicat
Yes, made the gearbox leak - gone back today!
Joking aside, they have dropped the transfer box and replaced the splined shaft that connects the main box to the transfer box. I saw an exploded view of the gearbox in another post and I am led to believe it was the short splined shaft.
Tony
Post #368766 1st Nov 2014 5:05pm
