![]() | Home > Technical > Disco transfer case - connections |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5854 ![]() ![]() |
Speedo drive
Diff lock High low |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5929 ![]() ![]() ![]() |
Cheers. So speedo drive - yellow arrow?
Hi/low the bit with the lever on and difflock the flat sided bolt? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
![]() Andy |
Excellent. Thanks 1999 Defender TD5 110
Just had mine put on yesterday and it's take a few miles to get used to but with the 110 being a 1.66 box and the disco being 1.22 the lack of screaming gearboxes is lovely for your ears
![]() Ray |
I hoping for a quieter drive as well. Lets hope it fixes my other transmission noise as well. 1999 Defender TD5 110
Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265 ![]() ![]() |
1.4 box in your 110 ![]() How is it, this is my next mod, does it make the difference? What happened with case? |
1.6 in My 110
What was it doing with a 1.6 box? Must have been fun on the motorway!
What was involved in the end then, did they just swap the gears into your existing box? |
Yeah, with the 1.6 on the way too and from France this year I didn't like taking it over 65 as it just felt uncomfortable and any faster you could see the fuel gauge going down
![]() We swapped over the front drive flange, rear output casing, shaft flange etc complete and the difflock linkage/tower which all took around 20 mins (thanks for the info fat boy slim ![]() Ray |
