Home > Technical > Disco transfer case - connections
excossack
Just taken delivery of the Disco TC. Just wondering what goes where.
See pictures with white squares and arrows.
 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #367070 25th Oct 2014 1:52pm
landy andy
Speedo drive
Diff lock
High low
Post #367072 25th Oct 2014 2:19pm
excossack
Cheers. So speedo drive - yellow arrow?
Hi/low the bit with the lever on and difflock the flat sided bolt? 1999 Defender TD5 110
Regards
John M0VAZ
Post #367076 25th Oct 2014 2:37pm
landy andy
Thumbs Up Correct
Andy
Post #367083 25th Oct 2014 3:54pm
excossack
Excellent. Thanks 1999 Defender TD5 110
Regards
John M0VAZ
Post #367085 25th Oct 2014 3:59pm
mk1collector
Just had mine put on yesterday and it's take a few miles to get used to but with the 110 being a 1.66 box and the disco being 1.22 the lack of screaming gearboxes is lovely for your ears Mr. Green hopefully I might get a few more mpg too.
Ray
Post #367109 25th Oct 2014 5:50pm
excossack
I hoping for a quieter drive as well. Lets hope it fixes my other transmission noise as well. 1999 Defender TD5 110
Regards
John M0VAZ
Post #367123 25th Oct 2014 6:38pm
Tiger
Quote:
110 being a 1.66
1.4 box in your 110 Thumbs Up
How is it, this is my next mod, does it make the difference?
What happened with case?
Post #367161 25th Oct 2014 9:23pm
mk1collector
1.6 in My 110 Whistle I've only done 40/50 miles but it's a lot quieter drive and all the bit swap over easy Thumbs Up
Post #367176 25th Oct 2014 11:10pm
Tiger
What was it doing with a 1.6 box? Must have been fun on the motorway!
What was involved in the end then, did they just swap the gears into your existing box?
Post #367183 26th Oct 2014 7:49am
mk1collector
Yeah, with the 1.6 on the way too and from France this year I didn't like taking it over 65 as it just felt uncomfortable and any faster you could see the fuel gauge going down Shocked it's so much quieter driving around town but I haven't had time to stretch its legs yet so I'll report back when I've had a decent run, and on mpg difference. Mine used to be a rocket setting off but it's takes a bit more revs now which is what I've been getting used to, but I suppose it's to be expected going from 1.6 to 1.2.
We swapped over the front drive flange, rear output casing, shaft flange etc complete and the difflock linkage/tower which all took around 20 mins (thanks for the info fat boy slim Thumbs Up ) just use good sealer to stick them back together. Mine was having the DMF and clutch done anyway so it made sense to put it on at the same time although this meant I didn't have the time to refurb the box. But touch wood it seems to be ok.
Ray
Post #367226 26th Oct 2014 1:13pm
