![]() | Home > Maintenance & Modifications > Removing waxoyl from paintwork |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
WD40 maybe, work on small areas with something that definitely is NON abrasive.
Keep checking as you go that do damage is created just in case but it should come off fine with patience. Don't be too rough and the the WD40 have a few mins to activate. I can't see why it wouldn't work. Afterwards give it a normal clean off /wash to get residue and oil off. |
is it under the front arches ?
is the spray they have put on dry ? |
p90 Member Since: 24 Oct 2014 Location: Belfast Posts: 4 ![]() ![]() ![]() |
They have sprayed under front and rear arches. it has only sprayed up the back though. imagine around the filler cap.
looking underneath it looks like a neat and tidy job, not wet but tacky, rubs off on my finger. to be honest I'm not sure how waxoyl should be as this is a first. I'm half tempted to make it their problem and tell them to come and clean it up properly but thought i would check here first. I had a few warranty issues / recall on an intercooler hose and just thought i would use the genuine dealer for the first service. |
Watered down White Spirit.....DIY in future
DIY i think is the way to go. i wasn't aware they where doing this just got told when it arrived back.
Does waxoyl actually dry completely hard or is it just a tacky finish? |
DLK Member Since: 12 Mar 2013 Location: Scheveningen Posts: 70 ![]() ![]() ![]() |
Plain old diesel works perfectly!
It kinda never dries, ever,it stays slightly wet in order for it to "spread" over stone chips/damage,etc. Pov.spec,ftw. 2006, 110,TD5.
defendercorner Member Since: 17 Feb 2014 Location: Pembrokeshire Posts: 59 ![]() ![]() ![]() |
I've used autoglym tar remover before to remove over sprayed way oil. Worked well.
![]() 2012 110 2.2 XS DC 2003 110 TD5 County DC (now sold) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3655 ![]() ![]() ![]() |
#2 for white spirit on a micro fibre cloth, and then immediately wash the car with a good quality wash and wax. Try the white spirits on a small hidden bit first but it hasn't effected my paint where I used it DEFENDER 90 TDCI XS,
Is it Waxoyl or some other wax product? Whatever, I've rustproofed enough vehicles to be able to say pretty much all of them will come off with a mild solvent such as white spirit, turps, petrol, diesel etc on a soft cloth. Always test on a discreet area first and don't be tempted to rub too hard as this can scratch the paint / lacquer. Don't smoke! Steve.
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 524 ![]() |
Petrol is the cheapest and quickest. Wear rubber gloves
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5805 ![]() ![]() |
Petrol soaked cloth. Easily removed
Andy |
Lou Sparts Member Since: 15 Apr 2012 Location: Kent Posts: 1501 ![]() ![]() ![]() |
Petrol is cheapest as stated but diesel goes further ! 2005 Td5 90 XS
Steve |
Leenorthants Member Since: 08 Sep 2013 Location: Silverstone(ish) Posts: 861 ![]() ![]() |
Cheap baby wipes, trust me they get everything off everything!
