Home > In Car Electronics > Split charger and power inverter
Cat81
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Orkney Grey
Hi,
I am looking at installing a double battery system + split charger + power inverter. I see there are a lot of posts on this topic, and hopefully will not repeat the existing (e.g., which between ACR / VSR; Blue Sea vs IBS; etc). My plan is to have a starting battery and run anything else on the Aux (additional lights; fridge when needed; power inverter for kettle, computer, chargers, etc).
A camping van specialist has actually recommended I go for a different system (obviously, a pricy one Rolling Eyes ) - and use either a Mastervolt Mass Combi or a Victron unit to serve my needs. That would be combined to my existing battery + additional gel unit (something like GBP 900 in itself ...).
Has anyone looked at a similar set-up in a Defender? It looks like a complete overkill to me (especially since I hear so many good things about simpler systems) but I'd like to get another opinion before dismissing it ...
thanks!
Marc
Post #366362 22nd Oct 2014 8:45am
Tiger
Sounds like a serious set up. Shocked
Don't want to come over all preachy but do you really need such a set up?
Decent Fridge is money well invested, we use our Engel for all manner of stuff and it works well for us on a basic leisure battery (�70 job) will run for about 3-4 days on this without running the car.
I use a heavy duty relay and have a homemade split charge.
We have a cheapo Halfords (Ring Can) that is a basic inverted but is used for charging laptops etc.
Kettles require power! So we boil our water on a stove (Jetboil)
So I guess the split charge becomes less complex if you look at the things you're running.
Post #366366 22nd Oct 2014 9:18am
K9F
As you so justifiably stated there are a myriad of threads on here with very good feedback and installation instructions with pictures on several renowned and well-tested makes.
Why are so even considering splurging more cash than necessary on an 'overkill' system (your opinion, not mine) on a system recommended by one when there is a lot of information readily available already on numerous others?
�900 on a gel unit alone? Shocked ......Was he wearing a mask and carrying a musket or big floppy shoes and a red nose?
Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #366367 22nd Oct 2014 9:19am
Cat81
Unfortunately not, that may have made things clearer to me Very Happy
Let no one start thinking they can sell me their used battery for that sort of price though ... Laughing
Post #366374 22nd Oct 2014 9:43am
captain slow
United Kingdom 2014 Defender 110 Puma 2.2 CSW Corris Grey
Has anyone used the CTEK D250S Dual Battery Charger? It seems like an elegant solution to me, but I'm not an electrical expert in by any stretch of the imagination! 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten)
300 Tdi 110 CSW (gone but not forgotten)
Post #366395 22nd Oct 2014 11:14am
K9F
Not a mention of that particular one but several mentioned here of the same brand.....
If I recall correctly our sister Disco site had some form of group buy/discount offered a while ago on CTEKs and an adaptor was available through Martin to charge through your tow socket?
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #366421 22nd Oct 2014 1:03pm
captain slow
Cheers, I'm also on the D3 site - I'll do a search there. Many thanks Thumbs Up 2.2 Tdci 110 XS CSW Corris Grey
Post #366424 22nd Oct 2014 1:17pm
VeeTee
Netherlands
I have my dual battery system running for over 5 years now, consisting of a Cyrix VSR (�50) and a Optima Yellowtop leisure battery (�180). Add some cable, connectors and other small hardware. I am very happy with this setup, and it is not very expensive.
I run a Waeco 40l compressor fridge on the Yellowtop, as wel as additional lights and phone chargers and the like. I also have a solar panel permanent on the roofrack for topping up the leisure battery while camping. Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #366448 22nd Oct 2014 4:17pm
munch90
post mentions kettle some kettles are 3kw that's a bl@@dy big inverter your need!
Post #366479 22nd Oct 2014 6:47pm
VeeTee
Netherlands
^^^ Indeed, it is best to avoid using an inverter: most laptops and mobile chargers work on 12V (or use a dc-dc converter).
And a fireplace is much more fun than an electric kettle Whistle
 Cheers, Vincent
MySite
Post #366496 22nd Oct 2014 7:40pm
munch90
can't beat a proper whistling kettle , electric aint camping ! Rolling with laughter
Post #366497 22nd Oct 2014 7:45pm
VeeTee
Netherlands
Glamping Rolling with laughter
Thumbs Up Cheers, Vincent
MySite
Post #366498 22nd Oct 2014 7:47pm
